What have you done to your 100 Series this week? (35 Viewers)
Tundra wheels and an eBay snorkel! I'm thrilled with how they both turned out
did the same for mine, really like the change in looks and handling. Did you Dremel out the front caps to fit them? I need to put mine on someday.
I just recently bought a 2000 Landcruiser and it seems to be in great shape so far! We have been taking it up into the mountains alot here on the western slope of Colorado. I look forward to learning alot form you all and glad to be a part of this community.
I'm including a picture that I took in front of Yankee Girl Mine the other day.
Sweet ride! Welcome. 🤙
Welcome, that is a beefy looking bumper.
Finally DONE with my garage refresh! Can't wait to just use it now! I filled in all of the expansion joints and then coated with Rustoleum Rocksolid in Metallic Blue. It is a little darker than I expected, but still looks good IMO. I am so excited to be able to roll my creeper or jack or engine hoist all over the floor without getting hung up on cracks or joints!
Before:
Rustoleum Rocksolid Metallic Blue: https://amzn.to/32zjOSk
Loctite PL: https://amzn.to/32yJq1O
Getting ready to finally put the front locker on
After almost 1,000 miles since I replaced the LBJs, UBJs and outer tie rods I decided to take a look at them for precautionary measures. I remember reading a thread about a fellow mudder having his ball joints fail without any warnings, so I just felt I had to check it. While at it I also rotated the tires.
p
Passenger side retightened okay but I went went king kong on the driver side UBJ castle but and probably may have stripped it. In the process I also wasn’t able to put in the lock pin.
In the process, I also wasn’t able to put in the lock pin since the hole doesn’t line up on one of the gaps of the castle nut. Any suggestions gents?
Before:
Loctite PL: Amazon.com: Loctite PL S20 Polyurethane Self Leveling Concrete Crack Sealant, 10 Ounce Cartridge, Masonry Gray (1618150): Home Improvement
What kind of prep work went into painting the floor @J1000 ? It looks awesome. Hot/warm tires won't lift the paint will they?
View attachment 2437633p
If you’ve torqued to spec, FSM says OK to tighten further until the holes line up.
Put a wrench on it and keep giving it some taps with a hammer until it lines up.
We recently had our driveway and garage pad repoured so I waited until it was fully cured and then used the Rustoleum Rocksolid kit which includes a concrete etcher to use before laying down the coating. Rocksolid is a polyurethane based floor coating that bonds very strongly to the concrete and is designed for garage floors. And yes it resista hot tire pickup.
