@87warrior - Which LRA are you using? Thanks
TLC100IFSEFR 40 gallon replacement.@87warrior - Which LRA are you using? Thanks
Thanks for sharing the pics. Please let us know how the rest of the install goes and how far below the frame does the big tank hang.Starting the LRA 40 gallon tank install. Gah, I hate the smell of fuel.
Stock tank slides out under the frame of my slightly lifted rig.
Stock fuel pump assembly about to be ruthlessly hacked up
Fuel pump bracket, float arm, fuel pump wiring and fuel return hose extended; plus a new Denso fuel pump and sock.
Looks great IMO, i've been looking into that for awhile now. What did you use to paint them?Repainted the LC wheels on my LX. Not perfect but should keep me from wanting to upgrade to 18" wheels for a while. Also debating on throwing the center caps back on, looks kinda better without.
View attachment 2202410View attachment 2202413
There is no skid for this tank, but the tank itself is pretty robust. Barring any problems, I hope to have it hung this evening.Defintetly curious how low this new 40 gal hangs down. Does it have any protection?
I really like your hard case for the dishware. Looks like it fits in there really nicely, too.I spent some time Sunday organizing my drawers to achieve a better flow when out camping.
Organization makes me happy, and helps at camp so you know where everything is.
View attachment 2208568View attachment 2208569View attachment 2208570View attachment 2208571
For those curious whats in the drawers here's a list I made for someone else on another site asking me what all's in there:
So in the right hand drawer I have vehicle based stuff, starting from the front of that drawer
The left drawer is camp kitchen/coking.
- I have the blue tarp with a small bungee,
- a CRKT fixed blade knife,
- viair compressor,
- a small plastic bin with the blue lid which has miscellaneous things such as leather work gloves spare winter gloves, electrical tape, a small 12v inverter, towing stuff (pin, plugs, small chain extensions) flint/steel random odds and ends.
- Toilet paper and duct tape
- an empty GSI bag that I keep on top.
- An LED lantern (1 of 4)
- the red case has jumper cables, various pliers and wire cutters.
- Then I have a rigid case from homedepot that I’ve removed the lid off, which has a 30ft 30k lbs snatch strap, a soft loop 25k tow strap, 3 Clevis shackles, and a hitch mounted recovery block.
- Then on top of that is a soft case that has sockets, wrenches, screwdrivers of various sizes that are specific to the truck.
- to the right of that recovery case I have an eastwing forged steel hatchet and then a smaller hatchet from the 60/70’s my grandfather gave me.
- Then a Stanley thermos/ frenchpress and an ice scraper and funnel to fill in the gaps.
- the steel case is the first item in that drawer it has plates, knives, utensils, cutting board salt/pepper shaker, soap, an aero press (blue bag) jet boil GSI mess kit for my pans, and Stanley pots that stack in one another.
- behind the kitchen kit is a GSI tea kettle, two 1lbs propane canisters
- the GSI soft bag on top of the propane canisters has fire starter stuff in it, so some cedar bark, some lint some paper napkins stuffed in there a K-bar bk11 knife, and a long nose lighter.
- the other three LED lanterns wrapped in/around a fleece Balaclava.
- my two burner Coleman triton stove
- Then a soft sided first aid kit (green bag in the back)
My drawers looked that organized the first time I used them a few weeks back. That is, until we needed recovery gear RIGHT FRICKEN NOW and the whole thing turned into a mess. I should take a page from your book and plan the organization.
Sanded with 400 grit and used a rustoleum metal primer. Basecoat is VHT graphite wheel paint. Clear was VHT glossy. Used 1 can of primer, 2 base, and 1 clear.Looks great IMO, i've been looking into that for awhile now. What did you use to paint them?
Gorgeous wheelsAfter 6 or so years...I finally talked myself into ponying up the dough to give my baby what she always deserved.
Done:
Slee front and rear bumpers
- Smitty built winch
- 4 Baja Design LEDs
Slee sliders
ARB snorkel
Heater T’s
“Fix” the pinch welds
Oil Change
Reinstalled OME heavy springs (anyone need OME light duty rear springs in Houston?)
Thursday
Mount and balance my 5 “new” 18” Tundra TRD wheels (powder coated bronze)
New OEM front pads and rotors
Soon
Front grille painted satin black
Maybe repaint then sun beaten front quarter panels
I did the same. Left the drawers to tools and gear. I put all of my straps, shackles etc in a rigid pro box.Ugh, been there. Keep the most often used recovery gear in a duffel bag. Fits in the drawers when you're cruising around normally, and you can pull the bag out and put it somewhere much easier to access when offroading. Plus the bag is easier to clean than the drawers.
