What have you done to your 100 Series this week? (17 Viewers)
WKOR sliders installed.
Let the hose replacement begin!
That and a new radiator cap...
Replaced broken ignition cam. Had to pull the column to get the broken piece out. No fun. Also delete a poorly installed aftermarket XM radio, from a previous owner.
Bought an 04 lx470 with 192k for a good price way below value. So far...
- Mobil 1 oil change with mobil 1 oil filter
- Timing belt and water pump kit.
- new Toyota coolant
- center exhaust muffler
- spark plugs
- front and rear diff fluid change with gaskets, and transfer case also.
- new denso air filter
- cleaned cabin air filter...
- greased the driveshaft all 6 points.
- replaced rear sway bar links
- replaced rear sway bar bushings
I'm getting ready to flush the AHC fluid, and all my speakers needs to be reformed.
Ordered a set of brakes a few months ago but finally got a free weekend to get the fronts done.
Repacked the hub and bearings. I did not replace the hub gasket, re-used the cone washers, hub races, hub seal and bearings. I plan on replacing the axles soon enough so curiosity wanted to see how well everything would hold up.
Enlisted the wife's help a bit to help clean the parts.
Can we get more deets? Mount, winch, etc...
Not sure what else to add...it’s the TT hidden winch mount, with a Comeup seal gen 2 9.5rs slim winch. If you have any questions about either, I’d be glad to help.
Was looking under the hood and realized the brake fluid needs to be flushed. No idea when the previous owner last did it. But it's dark and the pedal is a little soft
Took a trip to the West Virginia/Virginia border to see the fall colors, did not disappoint. I've never colors like this. All the fallen leaves made for interesting traction. The wife's sister visited to see the new baby girl (this was also her first trail ride, which went fantastic) so went for a picnic, made Hot Toddy's, and drove the trails.
I will say I'm terrible at taking pictures (and I dont ever remember to take vanity pictures of the truck or on the trail.
