What have you done to your 100 Series this week? (31 Viewers)
Glad you had a great time! BBNP is a truly amazing place to see (from October-April). Terlingua Abajo2 is awesome IMO. Great place to stay for an early sunrise visit of Santa Elena Canyon. Glen Springs 1 is great too as it's in the heart of the park and at the beginning of Black Gap. I can't believe you got one on Pine Canyon.....that one is usually booked solid year round. Great trailhead there for the Pine Canyon Trail to the waterfall. La Noria would be the only "boring" one out of those and it's not bad as it's on Old Ore.
Next time you go, reserve some time to drive all of Old Ore Road and go over to Terlingua Ranch so you can drive Christmas Mountain. Also, make a stop in Terlingua Ghost Town and eat at the Starlight Theater.
Glen Springs 1 is nice but very hard to find, esp in the dark.
First post in this thread for me
'06 LX470
Having great results using Dobinson rear springs (C59-221V, originally for 80 series) for AHC. This is with sensors maxed out on their original bracket. Helm joints up front were not shortened. Neutral pressure out back were about 6.0 give or take. Initial reactions showed that I had fairly strong rebound, without a lot of bounce. After a few days of settling this improved. Stopped by Lowes to buy 210lbs worth of Sand tube bags and the ride now better than stock. Rear also has 295/70/18 spare and 3rd row totalling over 300lbs. dissent bumper coming soon to replace those sandbags.
Again, the ride is much more compliant now with a lot more control with the stiffer spring after about 8k miles of driving. Rides like a dream with firmer bumps, nothing jarring. You guys with more AHC lift could benefit with this setup, without the sandbags and more weight capacity;).
I took a leap of faith with this one.
'06 LX470
View attachment 1943507View attachment 1943506View attachment 1943505
Off topic from your post but did you use por15 or some type of rush inhibitor on your undercarriage there?
The best it has driven since before the 36 hour race in 2016.
2 New lower control arms and 2 new axles.
Did you replace the frame side bushings too?
@Sargy Did you have a company do this or DIY it?
I hope so, a shop installed all of it. Where are they located?
Lower control arms come with only one bushing pressed in. The other bushing is pressed in to the frame and is not part of the control arm. Those bushings are a royal PITA and I am curious if the shop deemed them important to change or not.
I ask because I am on the fence to replace my LCAs and the frame side bushing scares me.
I know my lower control arms and bushings were trashed from some severe off roading in the 36 hour of uwharrie race in 2016.
I will ask them.
As smooth as it is now, I would bet yes.
@uzj100 Thanks. No, they are Black Rhino, Armory. 18x9 +6 offset. Been going back and forth on if I should get them. I like the utilitarian/industrial look of these.
Back in February, we towed our Travel Trailer for the first time with the Lexus. Other than being stuck in low height on the tow back home, it towed great. Since then, I've pulled Techstream numbers and have been giving the AHC system some lovin'. I've added King springs to the rear, flushed the AHC fluid and adjusted the torsion bars. My front numbers are 7.3 and my rears are 4.8. They were previously 8.0 and 7.1 respectively. I'm still tweaking the torsion bars so I can hit 6.8-6.9 up front. Otherwise, the numbers are looking good and the ride has improved vastly.
This past weekend, we pulled our Travel Trailer out onto the Oregon beach for the day. AHC system did great. I was able to lower and raise the system without issue.
The family had a blast on the beach. We had the Travel Trailer positioned to block the wind and had a fire going in the flame genie for about 7 hours straight. We stayed until shortly after sunset and then hitched up and headed home.
I was definitely nervous about towing the trailer onto the sand and getting stuck, but I came prepared. I had brought my Puma 12v pump in case we needed to air down as well as a trusty shovel and some recovery tracks. Luckily the sand was pretty packed still and we had no issue.
I had my wife and daughter jump out of the vehicle to film the entry onto the beach. I wanted a record of what happened, for better or worse. Video here.
Any idea what your trailer weighs?
Sticker weight dry is 3315. I would guess just under 4k with all the gear and water we were carrying.
