What have you done to your 100 Series this week? (47 Viewers)
My husband brought this home on Valentine's day.
The hell with flowers, jewelry, and cards. This is only 2500 lbs. so I can throw my pony in it and go!
My little one is in there testing it out.
Do you a company that does an exchange type service?
No, spare set I have that I had rebooted and checked to see if there were any grooves in the bells. Local place will machine the bell and put in bigger balls if needed. Fortunately not needed for these, just had one end that they replaced with a different one because of buggered up splines. Once I get the ones on my truck out and reboot/rebuild those, I'll probably offer them up as an exchange for Mud members. Would have to figure out pricing and what happens if the set I get from someone can't be rebuilt.
How many miles on and age of the current belt? It doesn't look too bad. Thanks.
I bought it with 180k and no maintenance records so I'm not sure when the belt was last replaced. Everything looked in decent condition but I wanted piece of mind before heading too deep into the woods :) The water pump gasket was paper, not metal like OEM, and pretty well degraded so it was probably due for a change anyway.
Threw on a new belt. The one that was on the rig when I bought looked like it'd fail at any moment. Super crispy!
The tensioner will get replaced soon. Idler was very smooth and had no play in it.
I extended the rear diff breather hose to account for lift ad increased travel/flex. I also added a little fuel filter instead of the factory breather which seemed to be gummed up.....I do NOT want to rebuild the wheel bearings prematurely by a faulty breather allowing pressure build up.....cheap insurance anyway.
Before going on a trip from California through NV, AZ, UT, ID, WY, MT, SD, IA, NE, KS and finally MO I took care of a couple things. I grinded off some rust on the rear hatch and applied some Rustoleum 'rust reformer' to it. It has a real nice rubber feel that is supposedly paintable, and it does feel and look like it will take paint very nicely. I have not applied my color matched paint yet, but below is a picture of what it looks like after 4 days of going through a car wash, on road and off road driving time (instructions recommends at least 24 hours), blizzard like conditions in northern Utah and southern Idaho (Teton Pass) and very heavy rains throughout. It has held up very nicely.
I also changed out my front brakes to match the rears that I did a few weeks back. These trucks really go through the pads, but it stops very strong, straight and smooth now. I tend to use Akebono wherever possible because they are quiet, long lasting and dust free. However this time, because I have had great results with them on big & heavy vehicles in the past i went with Duralast Gold components. The pads have a lifetime warranty that I have never had to use, but it is a nice bonus. These pads are also very quiet and provide a nice OEM feel.
Did the front sway bar disconnect too using some 3/8 inch pins from Homer Dee Poe. Took less than 10 minutes for both sides.
Left LA Wednesday morning and spent the night in south Salt Lake City. Then stopped in Green River Wyoming to visit with Reevesci. We stuck on my beautiful new sliders which he had already primered at my request so I could paint them later in my trip. Then we went for a short trip in his 98 LC100 equipped with a lot of nice equipment, including the Tough Dog suspension. This is my first time riding in a lifted LC100. So I cannot comment on feel in direct comparison to any other lifted set up on these Cruisers. However I have ridden in many lifted trucks. Most of the time the ride gets worse unless you spend a ton of cash and get things like extended (long travel) control arms, King remote reservoir shocks and other high end high cost components. And even then it is very difficult to match things up and get a nice ride on and off road while not sacrificing body roll control and general safe handling characteristics. So I think it best for me to compare it to my mostly stock set up. I have replaced my fsb bushings & brackets, links & link bushings. I have also replaced the rear links and bushings. Rancho RS9000xl with 9 position adjustability were added at all four corners, which I like a lot. I feel I should also mention that I am currently running Bfgoodrich KO2 305/70/16 E load tires which I run at 34 psi cold. My LC100 rides perfectly level (ZERO rake) when mostly unloaded, then when I add some weight I compensate a little withe the Ranchos, which I run 5 fr/5 rr when unloaded and 6fr/6 rr loaded. My Cruiser rides very, very nice. The Tough Dog suspension rode equally as nice as my suspension up front, while handling smaller impacts like washboard and similar ripples a bit better than my set up. I would rather not report much on how the rear tough dog suspension rode however because it was set up with the 'heavy' springs and was not loaded properly for that set up. It road nice in the back, but like all suspensions, it would have likely ridden better when tasked with the proper load for the spring rating. Not to mention, like when driving around in an unladen f-550 chassis cab truck, feedback and feel will be very poor. If I was to get a lift now, I would most definitely give the Tough Dog suspension a good hard look, I would probably just go with the 'medium' load rear springs as I do like a firmer ride and the added load carrying potential of a medium load spring for my modestly equipped Cruiser. Plus I love the anti fade properties of these foam cell type shocks. I have also become attached to shocks with external adjustability, from the Ranchos on my LC100 to the Ohlins on my GSX-R 1000 and the Koni yellows on my 335i, the ability to adjust my suspension in this way has become something that I can no longer live without. So am am very happy to report that these Tough Dog shocks, which are super beefy looking and feeling, are also 9 position externally adjustable.
Yesterday me, my brother and his son went out in the mountains near Wolf Creek, Montana and drove through some rather hard snow tha was also 3-4 feet deep. I think I lodged some of this snow over the TJM skid plates and disconnected my air line to my TJM front locker...:(:mad::censor::doh:. So today my project has already begun to remove the TJM skidplates and OEM front skid plate to make the necessary repairs. Just waiting for the temps to creep up closer to 50 degrees before I crawl around on the icy ground.
tana
Replaced the front swaybar links and bushings - I think I got all I was going to get out of the old ones:
I received my E-Bay chipped key transponders ($60 for 2). I was able to have a local locksmith cut for $3 each. I programmed them to be master keys using the gas pedal/brake pedal sequence. It worked. I order some valets. Life is good.
Didn't like where I had my backup camera monitor (inside center console ), moved it to the shifter area....much better!
I changed the front diff, transfer case, and rear diff fluid. I grabbed some samples and I will send them to Blackstone Labs along with my oil sample from yesterday. I also replaced the intake air filter. Next weekend, weather permitting, I'll change the spark plugs and rear brake pads.
Got my newly re-wrapped steering wheel & leather shifter last week and finally had the time to install it this weekend. I also replaced the airbag, replaced all gauge cluster backlight & center console bulbs to LED
Replaced the boring fog lamp bulbs with some yellow LEDs.
Got my first set of A/T tires put on yesterday. Falken Wildpeak A/T3W in 285/75r16. The running boards will come off in a month or so after my parents visit...they won't be able to get in without them.
Sounds like a good reason to get some sliders...or slider-steps, I mean.
Washed it this afternoon (78° in February!) then used my winch tonight to pull a friend's minivan out of the mud - he had gotten lost out on some backroads trying to get back home and pulled off the road to figure out where he was. Sunk right up to his axles, but was no match for a 12k winch.
