We all seems to have different sized bananasSure this a 1job?
What year is your cruiser?
It definitely felt more like a 1 1/2
job to meFollow along with the video below to see how to install our site as a web app on your home screen.
job to meIt's just a baby.
done a great job, what did you use for clear coat?Painted my hood. When you live in Texas or Arizona....you pay a 'Sun Tax' and some of the Clear-Coat on my hood was getting kind of cloudy.
It doesn't help that my LX is 'Smoky Topaz Mica'. So I sanded all the clear coat off and cut into the old base paint a bit, but shot over the top of that. 3 coats of base, let dry, 3 wet coats of catalyzed clear-coat.
Will need to let it cure a few days then cut and buff it.
Yeah the metalics are harder to shoot, but looks like the colour is bang on.
Looks great! How long did it take and cost for materials? I was quoted ~$500 for just the hood. You think that’s a fair price? Thanks!Painted my hood. When you live in Texas or Arizona....you pay a 'Sun Tax' and some of the Clear-Coat on my hood was getting kind of cloudy.
You have the touch. Paintwork is an art and science.Prep work *depending upon what is needed* will take most of your time. Also the quality of the finish will dictate whether or not you 'sand' between coats. In my case, I have about 7 hours in the job. I would not consider it 'Pro' quality work but the average person walking by would not see the difference.
$500.00 for a proper paint job on the hood is a bargain. This assumes good products being used. I was quoted $900.00 on mine.
Cost of materials for me amounted to Sand Paper, Masking Tape and plastic, and the paint components. I already had a respirator, a decent spray gun, compressor, Lacquer thinner for clean up, etc.....
All told....I probably have $150.00 in it. Depending upon the temperature and humidity your base coats *with medium activator* will dry in 15 minutes. I put down 3 coats. Let it dry/cure for 2 hours then came back and laid down a flash coat of clear, waited 10 minutes, a wet coat of clear, waited 20 minutes and final wet coat of clear. 2 hours later that was dry to the touch.
I will let it all harden a couple of days and then polish it out. I have a polisher and all the compounds. But even if I didn't polish it....it easily passes for a decent respray 'as is'.
Laying down the paint is the easy part. 'Prep Work' is the critical component.
I did my work with the hood on the vehicle because my Wife declined my request that she help me remove the hood.
But it would be a lot easier to do it OFF the vehicle.
Thank you so much for the detail step by step instructions! That is a lot of work and agree with you that $500 for a pro job is a bargain. Thanks again and great job on your hood paint. It looks like a pro work to me.Prep work *depending upon what is needed* will take most of your time. Also the quality of the finish will dictate whether or not you 'sand' between coats. In my case, I have about 7 hours in the job. I would not consider it 'Pro' quality work but the average person walking by would not see the difference.
Checking in from Alabama, with an LX that lived in Memphis the first 16-17 years... I think it's the paint. All the upward-facing surfaces of my truck look like absolute garbage, including the door handles and stuff. Hood and roof are trrrrrrashed.Painted my hood. When you live in Texas or Arizona....you pay a 'Sun Tax' and some of the Clear-Coat on my hood was getting kind of cloudy.
Did you spray outside or in your garage? I've got most of the stuff besides a spray gun, but honestly the thought of coating all the contents of everything indoors with a mist of Riverrock Green Pearlmica or whatever the paint is called (or having to build a temp spray booth...) has kept me from considering it too much.
I actually sprayed this outside *sort of*. My shop is so full of other projects I didn't want to move.
So I put up a canopy I already had 10'x10' and draped plastic down 3 sides. Had just enough room to move around. If I had removed the hood and put it on sawhorses I would have had much more room, but I did it with the hood still on the vehicle, so had to do a lot of masking. Hood off....would have been a piece of cake.
having owned my LX470 for almost a week now, i noticed that the PO had the rear hatch resprayed and the painter didn't do a good job of masking as there appears to be overspray. Any recommendation on getting that sorted? I thought about wet sanding it and polishing, I tried clay bar and it helped remove some of the overspray that was lighter but there's still a discernable texture that didn't come off with clay
