What Did You Do with Your 80 This Weekend? (58 Viewers)
Kids did the ice bucket challenge for ALS on the hood of my 80.
Video soon
Took the new pop top to the Los Padres for a test run.. Kids love the new"fort"..
I finally got it back from the body shop! After 5 months of fighting with my insurance company they finally agreed to fix it!
I really want to swap to those ↑ headlights!
A job that was waiting to be done for way too long.
Getting these daft 7 screws out was the most stressful part of the whole job. I had Vessel bits especially to mate with the JIS heads and even then all tried to cam out. Finally I came out with the method that worked well for all 7. I rolled (on the creeper) under the vehicle so my legs and hips were under the front axle. Then I could comfortably access the area between the radiator and the oil pump cover and hammer the JIS bit into each screw tightly (multiple taps). Then a socket and 1/4 ratchet and while pushing/keeping the bit tight into the screw head applying a quick 'jerk' to the ratchet to break each free. Was a great feeling as each broke free one by one.
They were replaced with torx head screws so this job will be trivial when done in the (far) future.
Obviously I replaced the crank seal - be crazy not to even though it didn't appear to be the source of the leaks. Picture below is the original prior to pulling out to install the new one.
New o-ring held in place with some vaseline. The old o-ring was dead as a door nail, brittle and broke into pieces as it was removed.
Used a breaker bar to break the crank bolt free (32mm on the S/C setup) and my 'SST' to hold the harmonic balancer assembly in place when re-torquing with a honking 3/4 drive torque wrench.
All up including a fresh oil/filter change it took about 6 hours including time to educate my two sons as they helped. This on a S/C 80 with dual batteries, so a little bit more stuff to deal with to get the radiator shroud off.
cheers,
george.
Just finished up my first real fab job for my 80. I had to lose the running boards cause I kept bending them up, but the wife and kid complained they had a hard time getting into to truck without them. Great excuse to weld up a set of sliders. Here's a teaser while I wait for the paint to dry. I'll go over it with a textured black before I hang them on.
...via IH8MUD app
Put my cruiser up on blocks for a few weeks. Began gutting the interior, pressure washed carpet, it's drying.
Removed door panels and disassembled, sent pieces off to musthave for some steel door panels.
It's Monday but I took the day off so it's still the weekend for me. :) About to do an oil change and slap a fumoto drain on (thanks for the idea @NLXTACY).
Just watched the video:
Interesting.... so you are happy with it? Any chance it will get hit offroad, or is it protected pretty well?
Do share, if ya do! :)
You are going to love it. Put the filter adaptor on and you will have three minute oil changes. I may YouTube my next oil change to show how quick my oil changes are now. :grinpimp:
  • Back
