What Did You Do with Your 80 This Weekend? (37 Viewers)
@LockedCollector 4k is a lot of weight. Your popup looks a little smaller than ours so I assumed it weighed less but looks can be deceiving. Our popup has shower, bathroom, etc. and 2 king beds (what coleman called a king anyway) so is on the heavier side. No slide-out helps the weight a bit and we try to not overpack or haul too much water. We are running 265/75/16s which I'm sure help w power and the 80 has rear air bags that help with balance when really loaded down. Our tekonsha brake controller also works well and the trailer brakes make a big difference on that side.
I can see how 4k and 295s would tip the balance in the wrong direction.
I love the old yak box too, perfect match for the 80 I think and a real asset when we are loaded up. Out West last year I tested moving the box to the camper roof and keeping the 80 roof clear and it made a huge difference with our ability to maintain interstate speeds. We won't run anything on the 80 roof while towing moving forward unless we are on a really short/local trip.
Took the LX to zero in a new red dot on a pistol.
Purchased another carry gun on the way back home.
Had a major oil leak due to a punctured oil feed line for my vacuum pump.
Poured some uv dye in the motor oil and found the leak right away
Got a good line for the local wreckyard and was able to finaggle it in place, by only unscrewing the power steering pump inlet.
New seat heater switches fit like a glove….
and finished up the front seats… (they’re katzkins…before anyone asks)
I thought they turned out pretty good considering it was my first time attempting this type of work.
Next step is to tackle the new carpet…
Installed the recovery points - 20 minutes as advertised
... and failed (attempt number three) to fit a dual usb into the existing spot.
I think Wits End has the hose for the delete
You are correct but I contacted Joey and they were in bound from Japan and couldn't get a ETA as they have not cleared customs at the time of our conversation.
But I was able to fix it and now back on the road.
This is what I used. No regerts
I have not stood on the rack yet and I am not a light small guy so I do not plan to ever put all my body weight on one bar. My understanding of the bowfin is that the rack is a system and all the load bars in place work together to distribute the weight kind of like a platform of a rooftop tent. I suppose I could check with Patrick, maybe with panels covering multiple bars you could walk on it but I don't think that's something I'd ever want to do.
I was on the fence between the @Delta VS and the bowfin. The bowfin was a surprise gift from my wife. If you've seen my rig, it's obvious I'm a huge Delta fanboy. They have a video of I believe. Dave standing with one foot on one of their crossbars on an 80.
If you're looking for that type of rigidity and strength, I would take a look at the Delta for sure.
I agree the @Delta VS roof rack is built like a tank.
I just did the rear heater hose delete. Worked like a champ but it is a bitch getting to the back of the firewall to get the old one off. FYI.....
Got the sheep skins on. My Korean Air buddy recommended them. He does regular ICN-LAX hauls in the A380s. A sheep skin covered seat is a critical part of how he stays comfortable in the office.
They regulate body temp really well. I get up around 5AM most days and the skins give me a bit of warmth and coziness in the cooler mornings. Afternoons heat up quite a bit here in LA and I'm pleasantly surprised how well it stays cool where my cow leather seats struggle.
I never thought I'd rock sheep skins, but it matches well with the vintagey 80. I highly recommend ussheepskins.com.
They look great. I've yet to hear a negative review of them.
I didn't do anything other than look at it and wish it had a bumper on it.
  • Vlex
