What did you do with your 60 this weekend? (4 Viewers)
Due to my AC compressor sitting up high, I couldn't use most of the air intake ideas I have seen here for V8 swaps. I used a combination of adapters and couplers and some 45* bent 4inch tube to get it over to the driver side. It's a bit tight, but works and now I have the correct size tubing...was running a 3 inch intake tube.
Part # 78303-90A03 is ALIVE once AGAIN !
and
is joined side by side with USA-SPEC. text Font LOGO CHOKE Part # 78303-90A02
FJ60 NON-USA-SPEC. INTERNATIONAL Language Butterfly LOGO Billet Aluminum CHOKE Knob
Vanity Fair. New Taillight Lenses from Mr. T. It took me to break one after having them survive for over 30 years. Originals were still in great shape but I replaced them because of the break. So great Toyota still makes these after all this time. Thanks to the mothership.
The PO installed a manual summit oil pressure gauge ..
Well it’s not OEM so it don’t fly in my world 🌎
So I removed its ambilical cord from my oil cooler filter mounting flange housing …
Installed a new OEM 2 wire updated sending unit .
Then started searching for the original Engine wire # 4 sub harness assy
Or what ever was left of it ?
I Quickly realized no trace of it was here or there ?
I deduced it was cut off flush at the main engine bay harness junction exit point most likely ?
And well it was just that after a hour or so of carfull hunting I un-raveled this yellow wire w / black tracer stripe stub !
The rest of the story is outlined below and I have in turn developed a updated version new and improved variety prototype of the original Engine Wire #4 oil pressure sending unit sub harness assy, with the reproduction rubber boot / cup cover I all-ready have going on ——
The updated ground tab wire will be tied in to a existing chassis ground circuit wire yet to be determined so hence left long …
Robber reproduction sender boot cover cap to be installed last step
Brought her home, nice to be back in a 60 again! :)
