What did you do with your 60 this weekend? (3 Viewers)
Well that looks awesome but it’s a switch I don’t have, for a circuit I don‘t use! 😢
Dude do I have a assortment of Dreamland unicorns rockers for you !
Vertical
Horizontal
All LED ALL the time .......
I have a bunch of prototypes to choose from I dialed in this past fall
Have you ever heard of the Rising Sun Mechanical Skunk Works Division ?
If not you will .....
Santa brought me a synthetic winch rope. Installed it today.
Upgraded my seats. Much better than the worn out stockers. The color is almost perfectly matched.
and finally my initial 88-90 FJ62 Rocker Switch Line Up , this is only in the final poro-type stages
there simply some many different ones to dig into , but oddly No Double inter illumination ones i have been looking for /....?
.first up is a rocker with the OEM
Original incandescent filament bulb
Looks awesome!!
Replaced the t-stat a couple of weeks ago and immediately after the 3FE had a high idle issue and threw a TPS code. This was really odd since the TPS and throttle body were not touched. Anyway, I tried resetting the TPS a couple of times without success and dove back in today with a better approach, using a vice to hold the throttle body and alligator clips on the multimeter probes when adjusting the TPS. Success except for a high idle. I also deleted the dash pot since the 3FE has been desmogged.
I came across a set of reproduction corner lights I had picked up a while back from a local. Used the OE bulb holder/reflector assemblies and the new rubber gaskets were a decent enough fit— the gaskets were missing anyway. I kept the Koitos for originality and might refinish them later but they are a bit cracked.
Also test fit some LED driving lights but the provided relay harnesses are set up individually… so I need to both extend the switch leg as well as splice in a second supply lead to run both lights off one harness.
  • Back
