Easy boys, we're all friends here
.Follow along with the video below to see how to install our site as a web app on your home screen.
.Rocks are not going to kick up and make a hole in the radiator. The frame crossmember provides significant protection. Besides, a rock can't be launched straight up vertically.
You know Matt!
There is a lot of useless things you do to your truck to many people. I’m sure they keep it to themselves as I have.
You have been trying to reinvent the wheel on these trucks.
I think these trucks have been around way longer than you have been around.
So if you have nothing nice to say keep it to yourself. I’m sure you have heard that from your parents.
Keep doing what your doing on your truck and let us do what we like to do in ours.
Hey Matt I think most of us here are just grumpy old men, don't worry you'll get here eventually. Just enjoy the journey.
Yeh....I beg to differ. .
Specially when driving on gravel or washboard roads....
It is not a common thing, but does happen.... and it sucks...
Bang, and then there was transmission fluid rushing out like a shower head
It usually happens in the middle of nowhere....
Im all for skid plates under that fat belly...... and good company...
Speaking of which, on a trip to Utah for a canyoneering adventure in the Upper Black Box of the San Rafael River, there was a stretch of gravel frontage road parallel to I-70 that had me tempted. It was about a mile and a half stretch that was wide and flat, and I wanted to see if the '84 FJ60 could keep up with traffic on the Interstate. I got it up to 70 mph before I had to slow down for the 90* bend where the frontage road turned north. There was some small gravel flying that day for sure. Luckily no damage to anything, but the FJ60 had its full complement of underside protection.Yeh....I beg to differ. .
Years ago me and a friend were out on a dirt road w/ my first truck and suddenly we heard a loud clunk and a scraping noise. We got out and spotted my exhaust shield had come apart from the outer edge of the frame area. We tied it up w/ a dog leash for the ride home. It was scrapped not long after too.You can have mine that I pulled off because it's a completely useless part and extra weight.
I mean you could have it if I didn't scrap it![]()
I’m 99% sure that’s where mine failed too.My rear washer line broke at the rubber between the lift gate and the body. I had seen some of the posts about trying to fish the hose above/behind the headliner. I found there was a double male connector just inside the body and enough slack at the reservoir to pull it toward the lift gate, so I only had to fish thru the lift gate. I did have to remove the bolt that held the ground wire for the defroster as the tubing hung up on it.
Make sure you re use that double male connector. That’s a check valve.My rear washer line broke at the rubber between the lift gate and the body. I had seen some of the posts about trying to fish the hose above/behind the headliner. I found there was a double male connector just inside the body and enough slack at the reservoir to pull it toward the lift gate, so I only had to fish thru the lift gate. I did have to remove the bolt that held the ground wire for the defroster as the tubing hung up on it.
All my wires were toast as well. I luckily had enough slack in the body to get a connector between those wires. I pulled out all the old wires in the hatch and rewired everything back there which was satisfying nonetheless. Now I got a working rear wiper, a rear light that comes on when the hatch is open and a heated rear glass panel in the back. Now lets see if it will hold up another 20 years.My rear washer line broke at the rubber between the lift gate and the body. I had seen some of the posts about trying to fish the hose above/behind the headliner. I found there was a double male connector just inside the body and enough slack at the reservoir to pull it toward the lift gate, so I only had to fish thru the lift gate. I did have to remove the bolt that held the ground wire for the defroster as the tubing hung up on it.
FWIW, the 70268 wasn’t big enough for my old 62. I went with a Derale atomic cooler with an electric fan.Assisted my helpers do The Rodney Flush today. These guys are used to the pressure machine, but I had printed out Rodney's procedures from the FAQ, and brought them the Valvoline Synthetic ATF Dexron. These guys are great and, despite never doing a flush like this, were game.
What an incredibly messy task! During the 2000 rpm flush run, the drain hose into the bucket got away from the tech that was holding it in place after about 45 seconds...and fluid blasted everywhere.Filling proved to be too slow to keep up with the idle runs, so there were about five or six flush runs at idle, then topping off again.
This tranny was rebuilt about 35K miles ago. There was virtually no friction debris on the screen or in the pan. There was a little fuzz on the magnets. The old fluid was not bright pink anymore, but was not brown either; kind of in between. We would use a pad of white paper towel to dip in the hose flow at the end of each flush to check the color. It took about 16 quarts of new ATF to get to a point where it now had a decidedly pink tint to it rather than a brown tint. It was not new bright pink, but definitely much cleaner.
I used a replacement OEM (cork) AT pan gasket. Didn't think quick enough to find a good vinyl one. The tech seemed to do a good job of using the cork. He spread a thin film of RTV on the pan surface, and they were very careful not to over-torque the pan back on.
Also replaced the transfer case oil with synthetic GL-5 90.
Next weekend we'll put on a B&M 70268 transcooler. I'll get that in on Monday and rig the position installation of the cooler. My guys will help with the "plumbing" of that next weekend.
Walked around a flea market, went and saw the San Xavier Mission church, and did some metal detecting off a random road about 30min north of the Mexico border. Beautiful day here in southern AZ.
I did, ya. I wasn’t having issues either really, until I installed a temp gauge and saw how warm it ran. The Derale cooled 30 degrees more than the B&M did.Thanks for the info. I saw your post on this elsewhere. I'm not having AT heat problems, I'm just being proactive about adding some cooling...and hopefully life. I already have taken up much room in front of the condenser with the 12" condenser fan. I don't think I could squeeze in the Derale or Mishimoto on the driver side due to the depth added by the fan.
Did you install yours in series with the OEM cooler in the radiator?
I’m game!We'll have to hook up for a cold one next time you're down.
