What Did You Do With Your 120 Today? (14 Viewers)
Smart Tap install = win! What a great little mod that is.
This was not fun with large hands! *edit* or in 100 degree heat either. LOL
Smart tap lets you use LEDs without hyperflash and lets you do a tap 3 signal lane change...and programmable hazard patterns. Just takes a harness to adapt to the 470 (swap one wire) but you lose DRLs.
What’s a smart tap?
Also, working in 100+ heat is no fun :(
@Vlad nailed it above. Strange that mine came with tap then four flashes programmed.
Here’s the link.
Installed a larger Hayden 678 transmission cooler in place of the OEM cooler using a bracket made by Mountain Passes Off-Road.
I don't have any hard data but just driving my son to/from YMCA which is only 2 miles away, I'd see ~170 degrees on my Scanguage. With the new cooler I've yet to see over ~155 degrees. The true test will have to wait until my next trip up to Big Bear. I'd frequently see 215+ degrees with no load/gear while climbing the mountain.
I had to relocate the horns underneath and extend the wiring.
The little bit of ATF fluid that came out of the hoses/cooler was pretty dark so I'm going to flush the entire system this weekend.
I only pulled 180 going over monarch pass in CO...you won't have any problems.
Installed some Wheelers bump stops up front.
I replaced my shifter boots lol. Lasted 17 years so I can't complain.
Found these Tacoma wheels on offer up. Add been sitting for a year and I gave it a long shot message. 80$ for all 4
waiting for a deal on some 285/70/r17 and took off the running board yesterday
Yeah- I need to do that. Are the boots available seperate from the whole center console cover?
Now that my brushed aluminium is here I should probably wrap the out of place wood trim. It's just so damn hot though.
