What did you do to your pig today? (17 Viewers)
Rusty tank/line woes???
Recently installed new (manual) fuel pump but still not getting gas to carb....put a gallon behind fuel pump and she pumped fine.
Figured must be in line or tank....blew out line and gas flushed out the back so I then thought ok....must be in tank. Started to drain gas (found a speck or two of rust) and then realized I only had roughly 2.5 gallons in the tank ( I would've swore more gas was in there and the rig is fairly level right now).
So I wonder fellow knights should I go ahead and pull the tank? I have not checked at the entry point of the tank (boy that's a hard place to get to!) or put more gas in the tank as the entry point(by entry point I mean the fittings connecting the gas tank to the fuel line) feeding the fuel lines to the front of rig is at the top of this tank....surely 2.5 gallons would feed/be pulled to the carb?:confused:
I'm guessing pull the tank...TIA for your advice, Dave
That sucks, lamb. What happened?
Not sure yet. Could be transfer or rear end. Transfer has some play in it, gunna drop the e brake and rear bearing housing today after work. Maybe pull the whole T-case. One step forward,...
Receiving shipments for install of dual battery kit on Monday.
Currently have:
National Luna dual battery kit
1 4-bank of DC outlets
1 3-bank of DC outlets
WallyWorld marine, deep cycle battery and marine (plastic) battery box
Waiting to arrive:
4 marine grade, single DC outlets
Cobra 1500w inverter
Blue Sea fuse box
Still need to get wiring - but might wait on that until Monday, lay everything out, and hopefully pick up all the wiring I need in one trip to the store.
I can't take credit for that , I got the idea from Scottryana. Check out the link to his build. Make sure you tie the rear body mount to the rear quaeter to beef it up.
I hit mine hard enough last week to bend the I-beam on the high lift. It is definitely important to make it strong if you wheel in the midwest.
WOW :doh:
Removed the dash pad and all the old heater/choke controls I won't be needing anymore.
I know someone who wants all that crap. "animaldevictor" in Costa Rica is looking for that stuff.
What up jtrock26 why not. It get cold in Boise ID!
Will be replacing the heater with an aftermarket system and also doing a custom dash eventually, so out with the old!
Painted the area between the dash pad and the windshield.
Installed two 'cubby holes' or whatever you want to call them as part of my sleeping/storage platform.
Prepped for dual battery install.
:cheers:
New 80 series master cylinder, new Monte calipers and brake pads for the rear. Finally the truck stops! Still needs a little bleeding.
Hit the underside with some rustoleum to stop some minor surface rust that popped up. Looks purdy.
80 series MC not workin out so well.....
Really? Are you using it with stock axles, with disc conversion? Sorry I am not up to date on everyone's builds anymore, but am kind of getting the bug back. lol.
Ryan.
not quite finished, but here's the first one
