What did you do to your pig today?
Blew out my lines......put in fresh gas. God I love :steer: it
not quite finished, but here's the first one
Freakin' Sweet! Love those. I know what I am doing with my extra set of doors now!
:grinpimp: Thanks
Drivers front is going to be a bitch. The donor door has a 2"x4" hole where the bottom hinge mounts. Gonna try to patch it up. Either way, I'm picking up another set of doors this week.
Wife thinks I'm crazy :meh:
gonna eventually do the rears as well. just worried about the dogs falling/jumping out at inopurtune times
:grinpimp: Thanks
My wife thinks I am crazy anyway so I just do what I want! ha :D
Yes I got to pull that trick off myself. I'm going to use alittle more mig, and leave the rivet gun in the tool box. They still look really good!
thanks
I went with rivits because each piece is total trial and error. Plus I was afraid of warping stuff. That's alot of linear footage when you look at it.
I'm going to use some grey indoor/outdoor as an inner panel and wrap over the "arm rest"
Tried to extract the t case fromunda the rig. Got stuck on that darn big nut at the back of the transmission output shaft. Can't seem to get the shaft to lock/bind enough to turn the nut off.
What I do is leave the front drive shaft on, put the truck in 4WD, lock the hubs, block the wheels and have at it.
If the tranny/transfer are out of the truck then pull the tranny top cover and engage reverse AND a forward gear. That locks up the tranny and then you can remove the nut.
If all else fails, get the SST to hold the drive shaft flanges.
second that. i've been thinking about doin this for a little while. glad to see that they turned out looking so good.
impact wrench
Cruiser_guy and Gumby, I thank you. I will get it today.....
I don't think I'll ever try to install a rear main w/o dropping the pan. Decided to go that route first time out- get a look at the bottom end and ensure that the pan shouldn't leak either- soooooo easy, bit frustrating w/ the 4 piece gasket- I'll go one piece next time-but I got it and don't have any leaks THERE(side cover now) Rear main just slips right onto the crank. All finesse....
