What did you do on your 70 series today? (14 Viewers)
Interested to see how this works out long term because I'd like to do the same. Every example I've driven, including our own, has this hood shake.
We use a 3M expanding foam designed to go in gaps and stop shaking/rattles. You can buy at automotive paint shops.
Cheers
Added an old turbo badge.
Nothing major just finally decided to redo the door cards as they were cracking apart, and covered in the previous owners paint (hopefuly). I got some gray vegan leather with adhesive. The only issue i had was the fact that it was a bit hard to cut and the 78 little holes that were there for the vents. Managed to 3D print some little inserts that make it look nicer, wanted them to also be in gray but i ran out so black it is, they are covered by the seats anyway.
I think it turned out nice, but still waiting for more clips.
Hello hello , what’s going on here?
Front transfer box output propshaft. Don’t think the copper ring is OEM,
Removed the ring and huge slop….kaput!
Fuel tank just sand blasted, and a coat of epoxy primer….
Added new over license plate part and coco mats.
Do you have a number for that or name?
Don’t have any in stock so no. They make two types though, one type expands to much and may damage your hood. That’s not the type you want to use.
It’s super messy too!
Cheers
How long has this been a thing in the back of the glove box?
Worked on front and back. Tire carrier on the swing arm and try to fit the winch. The winch relay box designed to sit right in the middle. I really don't like blocking the air flow so I'll build a bracket to sit over the motor (passenger side).
Also I'm searching for a rim for my spare to match the other 4 rims mounted on the rig. If anyone has a clue where I can get one. Cheers!!!
Got my bumper back from the powder coater. Look pretty good. Got the warn 10k stuffed in there but still have to find a home for the control box and make some longer wires. Hoping Amazon brings my terminal lugs on time so I wrap this up.
I sorted out some winch wiring- using a master disconnect switch I had laying around to turn it on and off. I don't like that long hot wire going out to the winch. I'd rather switch the power on as needed.
Gave it a workout pulling my project 80 series on the trailer to get started on it. It's a triple locked socal truck under all the crud.
I need to get a winch on that trailer, but this
got me by
Got my number back from the powder coater. Look pretty good. Got the warn 10k stuffed in there but still have to find a home for the control box and make some longer wires. Hoping Amazon brings my terminal lugs on time so I wrap this up.
View attachment 3923846View attachment 3923857
That looks really good on there. The powder coat job looks well done too. Good mil thickness. Should last a long time.
Things I hope I never need to use. 😁
