What did you do on your 70 series today? (17 Viewers)
Washed it for the first time this summer, just as summer is more than half over.
Guys opinions please..... i have a leaking rear axle on the drivers side. (RHD). The bearing have just bieng done and the leak is not coming from the cv gasket. Where would it be leaking from? Inner hub seal? I did overfil the diff a bit but that was weeks ago now. Please sugestions...
Aren't the CV gaskets only on the front axle ?
Overfilling of the rear differential allowed oil to seep between the axle shaft and the seal. Now there is gear lube trapped inside the axle tube and that trapped gear lube will continue to get picked up by the axle shaft until it is gone from the axle tube.
The last time I was overseas I removed the Japanese radio which is limited in FM bandwidth and installed a Pioneer radio with USB and DVD player.
I am thinking to upgrade the speakers and do not want to cut holes in the doors to accommodate 6x9's.
Kenwood makes a performance series 4" 3 way flush mount speaker that fits in the factory location and is reported to sound much better than the factory speakers.
Polk Audio makes a 4" coax speaker that has a Marine IP55 certification.
Those Polks look nice.
Metallic burgundy i think it´s called... have to look it up.. have to order some for the blemishes to...
Mahogany Pearl 3N2 and i are not shore think its a bit light for that... can be 3H4 Medium Red Pearl but that is not offered in 1999.. Had to check its 3H4 and its the original paint for this truck... funny that the Land cruiser differs so much depending on witch continent its sold.
I have a 93 PZJ75 pickup with the original Cardinal Red 3H7.
If the leak is not from the axle/hub it is probably when you slid the axle back into housing you knocked the axle seal. Also check that the breather is not blocked.
