What did you do on your 70 series today?
Might have just missed you at DEQ. The tech handed me his card and casually told me he would buy it if I ever considered it.
Now that she is plated I can get to work on 'fixing' (partially deleting) the restrictive full length exhaust. So many holes in it now I might as well!
Left seat (drivers) is worn out n torn. Had to change seats bot 2 front seats n swapped them. Direct swap no issue. Except passenger gets best seat. Will swap bases another time. Now 1 less issue to deal with for safety cert. after 14 yrs parked in a garage she'll be a legal beagle
Pulled the OME shackles to clean the pins up and re-grease. Not the first Cruiser I've seen with the anti inversion shackles installed the wrong way (and upside down in this case) :hmm:
Made a good start on a rack to hold ramping gear.
This thing is even uglier in real life.
This wheel/spacer combination responds very well to the 89-94 IFS Pickup steel wheel open caps.
Stance with 1.5 spacers and 285/75/16 rubber
On the subject of wider stance and stability --
If one were willing to undertake the cost and custom work required what would be the pitfalls of leaf sprung 80 axles under a 70?
I know linked 80 axle setups have been used with seeming success.
I reckon the steering would be the most involved part of the idea.
Way wide and very complicated. You basically take a vehicle that can be operated under any conditions and turn it into a low speed trail truck.
You pays your money and takes your pick.
Got a compressor for 20bux of the local scrap dealer to rape fittings off.. im making a small tank too fit under the deck . Should be all done for about a 100 bux.
