Shes back. On the road at least. Still lots of little projects but can drive her now
My accomplishment is probably admitting that I earned the dunce award.
Weekend before last, I replaced my brake booster on my BJ70 with a new one. Once done, I took it for a test drive and found the brakes to be dragging in a big way. Returned to my shop, read the factory service manual for adjusting the brake pedal very carefully. I re-adjusted the pedal per the instructions and found no drag on my test drive, so I thought I was good. However, the next day when I drove to work I found that the front pads gradually built up drag after five miles (or so) to the point I didn't have enough power to get her in 5th gear on a down hill. Over the next few days I made several attempts at re-adjusting the pedal without any improvement.
On Friday, I gave up. I disconnected the vacuum from the brake booster and headed to a local shop Land Cruiser mechanic because he was confident that he could fix it. On the drive to the mechanic's shop, the brakes were dragging again so I turned around and took the BJ70 home. Back in my shop, I pulled the brake master cylinder. While contemplating my situation and clueless as to my next step, I looked over the master cylinder for any obvious problems and actuated it checking for good fluid discharge; which it appeared to be. Then I looked over the new booster and the original booster. At this point I noticed a big difference between the boosters that I had not noticed before. The actuator rod on the new booster extended ~1/2 inch further out from the mounting face then original booster. I went back to the service manual and found confirmation in the booster rebuild section that the actuation rod required adjustment. I adjusted it per the manual and my problem was solved.
The information was in the service manual all along and I failed to read all the sections required to properly set up a new brake booster. Certainly was a Homer Simpson moment ...![]()
LDowney,
I will be adjusting mine this week.
Did you improvise a special service tool to measure?
So I was correct!. Glad you got it squared away Larry.
That boat is great! What a little ripper!did some towing last weekend
I want your top where I get oneToday was "Bring your cruiser to work" day...which seems to be almost every day now.
The part number for the top is 65910-60110-A0 but there is a lot more involved to get the top installed.
Got a link to what all is required? Did some searching with that part number but can't find any other threads with it. I'm guessing you need at least some bars?
Yikes. I was more just curious about cost and parts required than anythingNot gonna install a soft top on my troopy. Was hoping someone had done a write up, I enjoy seeing pics and conversions like that.
