VSC OFF switch install. (3 Viewers)
Laziness? You priced a new rack lately? And BTW it takes more than 5 minutes to replace one.
Some of us with limited budgets and time, still need these vehicles to be drivable without being dangerous to the passengers and surrounding vehicles. This mod does that. No need to ascribe the intentions of others.
Land Cruiser is the wrong car for you if you’re on a budget. What next? Delete the brake booster warning because you can’t afford to replace it?
I thought I would add my install to this thread as I found it helpful but it seems like there was still some murkiness on the wiring of the on-off-on switch. I used a pre-wired one from amazon and it’s working flawlessly. I can now have all the Nannie’s on, vsc off or vsc and trac off.
From what I understand vsc is stability control and has so do with reducing vehicle yaw (like in a corner) and trac is traction control and regulates forward motion tire slip. It’s nice to have these individually as sometimes you need wheel flares to clean out tread in muddy conditions or just want to have fun in a snowy parking lot.
Either way I agree both of these are crucial safety features and I plan to keep them on for a majority of my driving, but I like to have the control to turn them off.
On a side note - I was having vsc interventions on winding roads and it is due to a failing steering rack (which was pointed out here). The rack is getting replaced, but I still like the ability to turn off systems when needed. So thank you to this thread for helping me diagnose that steering rack issue from those vsc interventions!
Anyways - here is my diagram and how I wired it:
Like the OP noted A43 pin from the connector at the ecu was connected to the middle wire. Ground to one and back to the pink/black wire for the other.
One thing I didn’t realize was that the on-off-on switch works opposite how I though (see below last photo) so when you have the switch depressed to “II” it connects the middle and the opposite wire (the one under the “I”). I had that backwards but hopefully the last image is helpful for those wiring it in.
Finally - confirmed that you can turn off vsc while driving. Then turn off track and vsc while driving but needs an engine key off and the switch back to vsc on to reset the system. Confirmed also that center diff lock and all other systems working as they should.
Thanks for all the help and I hope this helps any future installers!
Hi everyone...it's also valid for the 100 European...in the third connector I actually have the P/B wire...but if I look at the diagram taken from the internet it's all different..
this is not correct....vsc to ground you do nothing but make the light turn on..
The only times VSC has actually turned on for me have been around corners and sometimes on winding freeway exits. It really wakes you up and occasionally I need to change my pants after it happens. It once happened going up to big bear on icy roads… yeah I think I need to do this mod.
Could someone make a wiring diagram including the relay they used? I have small brain.
:bang:
I just did this mod after driving thru the mountains in Tennessee and the Carolinas. Sudden left front wheel braking at speed isn't something that I'm interested in. We are moving to Columbia SC and do not have a house to do the work. No time or place. Once we get into something I'll have a new rack installed. But this helps me out in the short term while I concentrate on other things.
Thanks for putting this together! Its saved me from more potential issues.
  • Back
