With @Shoredreamer leading the charge we are working on regearing a used Tase rebuilt with under-drive gears and new lower low-range gears. We were working on buttoning up the case tonight and realized that the VC of the donor case was fried. With the center diff unlocked the front and rear outputs were still locked together...
I spent the last hour reading threads about the VC but still don't understand if I need one or not. We have two other cases lying around and could pull one out with a bit more work.
Do I loose awd or ABS if I leave the VC out? It seems pretty common that people take it out. Is it just because its an expensive wear part that eventually fails?
My wife and I do a ton of driving (15 weeks a year typically) on icy roads to go skiing in Tahoe so I'm worried about loosing handling performance in these conditions.
Would appreciate any advice you guys have
