That's the truck. Most of what I am doing goes unnoticed unless you open the hood, stoop over and look under or look at the gauges, shifter and pedals. There will be some electrical changes as well, mostly unseen as well.
"shaker" ?? My brass tumbler doesn't seem to be able to do the job. What is this shaker you speak of? Maybe my media isn't course enough?Fresh out of the shaker. Most of any plating they had was already gone. Each gets anti seize, loctite, heads nuts and washers painted.
The rock tumbler I use does a nice job but it took a lot of trial & error. "Purple stuff" mixed with a couple cups of blasting media for about 4 hours = very good results.
Black Diamond Medium Blasting Abrasives - For Life Out Here
So I ordered a flasher relay to stop the super fast blinking when I put in LEDs in the turn signals. I already had put in resistors and the lights blinked fine, but thought the blinker relay might be a cleaner install and reduce things that could go wrong. Well, it would not work. I put the jumper on the relay and plugged it in and nothing. Put the OEM relay back in and it worked. Took out one of the resistors from an LED and tried it both ways....OEM worked both ways....new flasher relay wouldn't work at all. Any ideas?
