Bottom of truck and fire wall taken back to bare metal.
Primed with Red Oxide primer
Will the throwout bearing retainer off the 3-speed be correct for the 4-speed?
I did mean the input bearing retainer, and I’ll go with the 4-speed throwout bearing.Are you referring to the input bearing retainer? They are unique to each transmission, a 3-speed input bearing retainer only works on a 3-speed.
For the throwout bearing I’d swap to the late 4-speed style, it’s a much nicer design. You’ll probably need to use a 4-speed clutch fork to go with that.
Is the input bearing retainer what I have pictured on the 3-speed?
So I think I figured it out, I can use the throwout bearing off the 3-speed on the 4-speed transmission, it will fit over the bearing retainer, but the 4-speed throwout bearing is better.I did mean the input bearing retainer, and I’ll go with the 4-speed throwout bearing.
Don't throw away you're 3spd TO bearing or clutch fork. I'll throw you some dollars for them as spares...if you aren't using them.
They are both yoursAlso would take the F flywheel. @40LandCruising
Because I have a 350Why would you not run the 3-speed flywheel? They’re awesome off-road.
The master was installed by a reputable shop so I assume it wAs adjusted properly. And I bought NTK O2 sensors which are Who made OEM ones in 94. And I’ll have to look for a rip.no real idea just guessing.
was the push rod adjusted properly on the master cylinder when it was replaced?
maybe the soft brake lines are swelling when you apply the brakes?
what brand of o2 sensor did you purchase?
make sure there isn't a rip the lower intake tube near the throttle body.
