Truck has inconsistent and pulsating brakes at low speeds. (1 Viewer)
Have similar issue. I replaced pads/rotors and had to have one of them heat treated as pin was siesed.
I still have pulsating after over a year. Much less now than prior to replacing pads/rotors.
As an FYI it will probably go away but resurface later. On the next brake job i may swap callipers.
Have you checked out your wheel bearings?
Yeah, I had them done at same time I did the brake job. I couldn’t finish the fronts as caliper bolts were frozen and needed heat. So took it to local shop and had them do bearings.
Doing mine this weekend. Can't wait, I have the same issue as you. Though, I am also replacing both front Wheel bearings this weekend. you know, "While you're in there" kind of thing.
It's just happenstance that it needs brakes and rotors, too. :)
Are you doing the brake lines too? I ordered 4 new ones for the rear but couldn’t get them off without almost rounding the bolts that connect to the hard lines.
Not doing brake lines until I see a reason, mine are fine currently.
