Hi all, I came across a TRD Supercharger for my 1994 Landcruiser.
Now it isn’t as simple as let’s bolt it on!
1. OBD1 computer will not handle the fuel control/ I added Haltec ECU 2500 to have idle and knock support, in parallel with oem ECUs Eng / Trans to maintain transmission shifting, speedo, cruise ect. With Duel Wideband 02s, IAT, coil over plug ignition, MAP internal to Haltech, ethanol sensor for e85, boost control of change to turbo, 4-1 can bus Haltech gauge, that’s the electronics
2. 850 matches flow injectors, with Hi flow e85 fuel pump upgrade, adjustable fuel pressure regulator and new fuel lines engine and one return at tank.
3. Removal of Air injecting system 94 only,
4. Either install wide band oem 02 sensor locations, or bung. I did bungs.
5. Wire harness modified engine l for throttle body relocation without cutting / extending wires.
6. Hester like change to no interfere with supercharger mounting.
7. Air filter top housing to keep for now VAF air flow meter and no hit the supercharger.
So this had been a process… with hopefully enough gains at the end. Once running, get an acceptable tune and drive it, either remove the Supercharger and proceed turbo or keep Supercharger and remote the engine / freashen it up lower / head and use Head studs going back together with all new coolant hoses, water pump ect.
I am at the Haltech harness integration now. Fuel system is completed and leak tested. Once wiring harness installed, rap up throttle body - radiator - fan - battery and coolant. Hopefully program the Haltect, commence fire in the hole!
