Maybe a stupid question, but doesn't the factory tach drive off the igniter (not the coil) and could you leave the igniter in without the coil to keep that signal to the tach but not worry about high voltage sparks?
Yes, the Aussies make some good stuff.The coil over plug conversion, used Yota coils and HD Automotive mills a bracket to bolt down where plug wire holders and covers attached.
Coils bolt that and they HD Auto provide the harness per OEM ECU or Haltech ECU. I have the Haltech 2500 ECU.
HD auto sales the block off plate for the distributor.
So when you remove the cap, rotor and wires it’s not open.
Assies… they all in on this stuff for Toyotas
HD Automotive sold me the conversion plug kit. It came optional 1. A or B brand of coil, 2. With oem ECU or aftermarket ECU terminated hardness with Dosch “however you spell it” connector. Haltech plug and play harness I paid to have made custom had the pigtail setup with corresponding connector on it. The Coil kit provided the 2nd half of the connected needed if you built your own harness.Yes, the Aussies make some good stuff.
So the coil on plug conversion included a harness with flying leads for the Haltech? Talk about making it easy. I have the Elite 2500 myself so I guess the coil on plug conversion is inherently the next mod on the list.
Would you mind sharing your Haltech file for those of us looking to convert to coil on plug?
I’m running the Wits End turbo. Haltech 2500 with boomslang piggyback harness for transmission control. Considering going coil on plug conversion……it never ends.What configuration are you running needing a Haltech may I Ask?
If you are running e85 you don’t need an intercooler.I was planning a intercooled 14 PSI capable external waste gate with 6boost manifold with stainless 3 inch exhaust system. Then a replacement Air box to plumb the turbo inlet to enclosed filter to fender intake.
I found this Supercharger and couldn’t pass on it. Bought the rest of the stuff if I decide remove Supercharger and go this turbo route.
The intercooling piping looked extremely complex plus a little work forming a J pipe lead off to mate to the new exhaust system..
I never welded stainless before with my tig machine.
Tex
How do you like that setup? What amount of boost do you run to not create hi IAT temps? I am seeing 100-190 degree temps from the SC now with the IAT in the intake plenum.I’m running the Wits End turbo. Haltech 2500 with boomslang piggyback harness for transmission control.
I’m running low boost ~7 psi. I don’t have a dedicated IAT, so it’s reading from the MAF sensor and I’m seeing similar temperatures, but no signs of ping or knock. I’m considering adding meth injection because an intercooler is very difficult with this setup.How do you like that setup? What amount of boost do you run to not create hi IAT temps? I am seeing 100-190 degree temps from the SC now with the IAT in the intake plenum.
Tex
Is that because of clock position of the turbo meaning back turned / front parallel to engine?I’m running low boost ~7 psi. I don’t have a dedicated IAT, so it’s reading from the MAF sensor and I’m seeing similar temperatures, but no signs of ping or knock. I’m considering adding meth injection because an intercooler is very difficult with this setup.
I’m happy with the Wits End kit, but it is not very friendly if you want to intercool, my only gripe.
Just the positioning of the turbo…really, meth injection would probably be sufficient if I’m looking at going no higher than10psi. The engine is stock, with really low mileage. In stock configuration, the 1FZ is more than equipped for 10psi IMO.Is that because of clock position of the turbo meaning back turned / front parallel to engine?
Or intercool plumbing itself duct plumbing?
I my planning, no experience mimd you use a V clamp turbo on a 6 boost manifold to have twist / clock ability to help with J pipe / intake connections. I was trying to avoid a cone filter on the end of a pipe setup sucking heat from engine compartment. If I could stand the look
Of a snorkel I understand it lowers IAT temps a good bit.
I was really leaning hard for a turbo and still
Am.
Did you mod your engine? Head studs or gasket change or rebuild change of pistons / rods?
Thanks
Tex
Besides the TRD supercharger I posted if you search my posts the bumpers and drawers, plus a lift. I finished my Kenwood high end head dvd wireless apply car play install with Alpine S series soeakers and R series amp. Disconnected all factored speakers and removed the oem sub. Working out a sub replacement and think I have something in mind for that. All new brake slotted dimpled rotors, new calipers, stainless steel brake hoses , and master cylinder. Should be lost on that too.This is so freaking rad. Well done; you keep a clean engine bay. What else have you done to the 80?
