1994 Landcruiser in Costa Rica - What to Expect?
Costa Rica
Hello all - I recently purchased a 1994 Toyota Landcruiser 80 series as my daily driver in Costa Rica. The vehicle seems to be in pretty good condition with only 116 k original miles, originally purchased in Texas and immediately shipped to Costa Rica. I have a very thorough record of oil changes, maintenance and repairs, original manual etc. Because I am in Costa Rica parts are not readily available here so I have to have stuff shipped to a mailbox in Miami and then they come here approx 5 days later at a cost of $10/lb. Mechanic labor here is pretty affordable. I am trying to be proactive and replace pieces that commonly fail so that I am not roadside waiting for parts from the US. My question is this - what parts would you recommend replacing proactively or at least ordering in advance and having on hand for future repairs. I am okay creating a little stockpile of necessary parts.
So far I am replacing the steering box and pitman, Mass Air flow sensor. I replaced all window motors and the struts on the rear hatch and am waiting on a new set of switches for the driver side door and the cables on the distrubutor. Of course I have changed all the fluids and serviced the brakes. I also have a new set of OEM fuel injectors and a fuel pump on the way. Any other recommendations on parts to get in advance? Thanks!
Here are some pics of the rig
Great looking truck! I’d replace the fuel filter and keep a spare. I don’t know what the fuel is like in Costa Rica but it can’t hurt. Fusible links, spare set of belts, alternator, starter, distributor cap, plugs and wires. I hope this helps.
Download the FSM from the resources section so you can troubleshoot most issues that come up.
This is great info and very helpful. I have been looking at an alternator and distrubutor cap. I will get some belts and a starter too.
The plastic heater control valve should probably be replaced if it hasn't already. Also check out all the coolant lines. It's usually recommended to replace the Pesky heater hose. It's a difficult to access short coolant line under the engine. How do the steering knuckles look?
Radiator, Radiator Cap(s), water pump, thermostat(s), Radiator Hose sets, Toyota Red coolant - if that's what's in it now. Apart from that I'd also get some spare common Relays and blade fuses to have on-hand.
Deivetrain & Suspension-wise; Knuckle Stud sets (*complete with studs, nuts and cone washers), drive flange hub studs and nuts, and spare Oil & Fuel Filters to facilitate routine maintenance.
