Tapage
Club 4X4 Panamá
Anyone here know the " code " for the " shorty " ..?
Correct. You'd want the underdrive.
I'll send you a pm Scotty!
Georg @ Valley Hybrids & Cruiser Brothers
Ok all this is exciting news...
I just have one more question, if one installed the 10% high range reduction gears & the 25% low rage gears does the 10% effect the final drive in low range? Meaning a 35% final reduction in low?
No, you don't add them up. Separate gears.
You can do the 3.11 low gear which will not affect the HI range at all.
@orangefj45 , george, I have the low range gears and 4.88's. Would these gears replace the current gear ratio when my OD button is depressed? So basiclaly with these installed I would have a higher OD button and the same gearing as I have now with the button not depressed?
Thanks,
Noah
I am so confused now. Is this a joke? Still confused.
OD is a function of the transmission, not transfer case.
So anyone know how much work is involved swapping these gears ?
And what other parts are needed?
I got a quote from a terrain tamer vendor in Europe and it is even more expensive than R&P swap including the fitting kit + getting someone to set up the diffs. Too bad, because I was really excited.
No, the end result would be the same as you removing your 4.88s and installing 4.39 gears in your diffs (if there was such a thing)
The UD gears would be the same as installing 5.37 gears, theoretically (assuming you were coming from 4.88s of course)
10% lower final drive, so would be like 4.51 in your diffs.So what would be the theoretical result of the under drive gears with the stock 4.10 diffs?
