I just wanted to document for those who choose to go with either trail gear, 4x4 innovation, marlin crawler, or all pro sliders. The ones you want are the 67’s or 68’s. The reason why I like these sliders on the lc is that I can fit them really tight compared to what’s out there except for the Rocky Mountains which fit pretty tight too.
As far as welding them up it’s pretty self explanatory cut the tubes to desired length/angle, I found using a worm drive circular saw with a metal blade worked the best, maybe a miter saw with a metal blade too would work great getting the angles right.
So far I just completed the driver side i’ll show pictures on what the measurements are and so forth.
I installed the trail gears,and have had great luck with them on my past rigs especially through the rubicon numerous times where you really need the side support going though the rocks. They do get banged up but this time I reinforced the center with 1/4 plate (4x12) which should give it extra support and was the normal area where they would bend in. I also fabricated 4 mounts instead 3 which I can tell really stiffen it up.
Measurements
3 inches from the rear bottom line
Follow in front of the bottom line to get them straight, you want to be about 1/2 away from it both under and to the side
And 3 inches away from the body(top measurement)
I also put a paint stick on the front and the rear of of the slider to push it away from the body. Don’t worry the first time you use them you may crease those areas but at least they wouldn’t be crushed without sliders.
This set up may not be for all and keep in mind that I like my sliders as high and away as possible. The body on these cruisers are already wide enough so why make it even more wider.
Measurements
