- Joined
- Jul 22, 2012
- Threads
- 639
- Messages
- 17,560
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
Because the later L brackets were riveted to the frame I was asking what people are using to replace them. When I picked up a late FJ60 crossmember I was not prepared to drill rivets off the frame. Unlike previous years the late 60 series uses L brackets on the inside and outside of the frame making a total of four brackets. Unless I'm mistaken the FJ62 L brackets are further back. Crossmember supports the adapter between the transmission and transfer case.
The H55F started 10/82 in some markets. I wasn't sure if the body change 11/84 inost markets when the 3F bellhousing started would cause a clearance problem when mixed.
About the around 3/4" change between bellhousingss where was that measured? My only 60 series is an FJ62. What I have checked out is the two FJ60 four transmission shift canes in a FJ40. The early clears the driver's seat and later is right up against the seat. If 3/4" is how much the shift tower rotors it will be a lot more at the end of the shift cane.
Asked about the skid plate because I searched and the part number for our 4/85-7/87 skid plate shows a different part number that other markets withA five speed.
I suffer from OCD. Been collecting parts slowly for the H55F conversion into my FJ62. I seen a picture of one converted that has a transmission boot from model before 4/85. Most wouldn't notice it. To me it was if was painted bright orange. Most people would be happy to have one of these to install a H55F into a 40 series.
I'm still working on getting parts that includes this here from Australia.
You have been collecting a bunch of parts but I have actually done a bunch of these conversions, several of them for paying customers. Seriously, either combo works just fine as long as the bellhousing and crossmember match.
There is no issue with shifters in a 60.
