- Joined
- Jul 22, 2012
- Threads
- 639
- Messages
- 17,560
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
I have a brand new VHT cabinet.@cruisermatt what vapor blaster setup do you have?
Thanks!
Thanks!
I wish I could get the outside of the t case as clean
Well that’s pretty disappointing… no 3f stamp that I can see. I guess the guy sold/sent wrong stuff. Anyone got correct bellhousing fo sale?!
Looks like your going to stay with the earlier bellhousing. Keep in mind you will need to bend the shifter to the right. The 10/82-11/84 H55F shifter very hard to find. This will also move the transfer case shifter to left as well. Have you test fitted the mounted transmission without the correct crossmember restricting the transmission from being raised to the correct location? I'm not sure if there will be clearance issues.
Few questions some might know the answer too.
On this conversion what L brackets are being used for the correct crossmember? Unlike the earlier version that were bolted to the frame these L brackets were riveted to the frame.
Will the late FJ60 skid plate work on the H55F in a FJ62?
If using 80-84 bellhousing use the 80-84 crossmember and brackets. Simple as that. I have welded in the L-brackets and I have drilled holes and bolted them in. Either way works.
No clearance issues with shifters. It’s only about 3/4” difference.
Well, if he is going that route may want the earlier DC driveshaft as well. I generally like to upgrade to newer stuff as it usually provides improvements so, if it was me, I would just get the correct newer bell. They should not be difficult to find.If using 80-84 bellhousing use the 80-84 crossmember and brackets. Simple as that. I have welded in the L-brackets and I have drilled holes and bolted them in. Either way works.
