TLCA TLCA Rubithon Wagon Run (26 Viewers)
the voice of experience speaks...
(Where's my kid?? he said frantically. (Great Story we still tell around the campfire)
The Rubicon Trail will not be the toughest trail you've driven. Pritchett in 2019? was much worse obstacle wise. But it is like running a Marathon. It is constant. You have to have your A game ready the whole trip. It is the little obstacles that wear you down. So the more you can do to avoid fatigue the better. I say this because you have a sizable road trip to start with.
This is sage advise Eric, and it will be heeded.
The original plan was to arrive at the Mckinney side Tuesday morning to prep trucks and drop off all our crap. Take a leisurely drive around Lake Tahoe, stop for lunch, and arrive at Loon late in the afternoon to get a reasonable amount of sleep. We're also not really rolling long days on the way out, as I do need my beauty rest.
Mark and I will discuss your option.
And it was good times on Pritchett (2017), although I could have done without the winch cables catching fire ;)
I sent an email to Ray on Monday regarding GMRS/ham/repeater info and got no response.
I offered to make a CHIRP/Excel file to help as I know how crazy things can get for the organizers before an event. I have no problem jumping in to help out if needed. All I need is the info.
I'll be bringing 2 Baofeng GMRS/2m/70cm handy's and a Kenwwood V71A unit in the truck. If folks are short of radios I have another 6 Baofeng units that I bought for our club events. I'd be happy to charge them up, preprogram them, and throw them in a bag if needed.
Personally, I don't want to have to be playing around with my radios when I'm getting ready to hit the trail.
I have been out of town this week and just saw you email, I can post the Rubicon repeater, the plan is to just use GMRS frequency’s I haven’t seen a list of what we are using yet, I will post and update the email thread as we get closer,
I can not do this from my Phone but if you wake up from your naps. And take 2 min to type in Rubicon trail Ham radio frequencies. you will be able to spend the rest of your evening looking at all the wonderful numbers . Try not to lose sleep over these since your run will be using GMRS Channel 🤷‍♂️. And that should take less than 12 seconds to program . Ray maybe you will need to schedule Naps. 🤷‍♂️. Let me know so we can call for radio silence during those times 👍.
Since I am doing this right now and going thru my 80 I thought I would post some area’s that have caused people trouble in the past,
1. Knuckle studs, check them torque them and paint mark them, if hey loosen they will snap, 70ft lbs, also drive flanges and studs same deal if they loosen they snap,
2. power steering, rocks, lockers and big tires are really hard on power steering, I highly recommend an add on cooler and synthetic hydraulic fluid (higher boiling point), every year I bring 4 quarts and it’s gone by the end due to someone leaking or boiling it out, (Napa has a good quality high pressure hose for your spare kit). Also check pitman shaft for twist at the splines, ( yes even the 105 shaft can twist) and the frame for steering box cracks, (yes I carry a spare steering box and hoses, if I get it back from Kade…he borrowed it…lol. ).
3. electrical add one’s. There are always issues with poorly done electrical add on’s. I keep the Toyota stuff on the factory battery and fuse box everything else comes of the second battery and fuse box (Jeep Cherokee has a nice one with a mounting bracket and plenty of fuses and relays). This makes it clean and easy to isolate if there is an issue, try and keep wiring clean and protected from heat and vibration,
4, oil and fluid leaks, Rubicon foundation has worked really hard to keep the trail open and clean, we have spill packs and can clean up from issues, but give your rig a good once Over and look for anything that might cause an issue, now is the time to deal with it, it’s much nicer to do in the garage on the concrete than on the trail in the dirt.. Rubber doesn’t last forever, just did the rear heater hoses underneath and I’m surprised they went leaking as they were toast..
5. 80 series guys, fender flares, at least remove the ones on the rear doors, or the trail will remove them for you, also if you don’t have a rear bumper rig something up for quarter panel protection, you will come off a rock and the corners are real vulnerable, It can be as simple as some tubing to give you a rub rail back there, 6” C channel works, anything to keep the rocks off the quarter panels..
6. Over packing, I’m guilty..80’s can get real heavy fast, the less weight up top the more stable the rig will be, ( awnings tend to find rocks/ trees if they hang out) bumpers, sliders and gear add up fast, now yes my 80 is a pig and heavy but think about what you are packing and don’t go overboard. Less weight less stress on drive train,
Thanks all for now, look forward to seeing you all and joying the week..
Somebody's a little tight this am. They don't want a refund they just want to ensure they are on point with requirements & comms for their EPIC journey to Rubithon. Good morning.
Radio’s aren’t really an issue on the Con like on other trails, ( that’s why the chairman is responding the way he is). We are usually closed up as a group and if someone stops everyone get out. As a club we do a lot of desert stuff and washboard at speed, there radio’s are essential, on rubicon you will be focused and moving real slow, especially in a wagon you have to look and plan your line as the obstacles are one after the next and you have to think 2 or 3 moves ahead so you are in the right lineup for the next move, stop paying attention or bs on the radio and you will be hung up no joke,
last year I think I talked on the radio twice and once was to respond to a insult I deserved, where the radios come in to play is when we have issues or people get hung up.
Speaking of radios, I still need to get one, would this be a good purchase? - BAOFENG UV-5G (UV-5X) GMRS Handheld Radio, 2 Pack
Or would you guys suggest something else? I know nearly nothing on this subject, I'd like to get something handheld rather than modifying my dash.
I have 2 of these that go on all the runs with me and on hikes, especially if I take off with my bag and camera for a morning at Rubithon. They work great out there. I added a Nagoya 15.6 whip onto the one I hike with and it does pretty good out there
Also, if not wanting to modify your dash, I highly reccomend the Midland MXT275. I have one in our Sequoia and it's nice
Thank you. For someone who has never run this trail and is used to having trucks getting pretty spread out during a run, this is good intel.
