How much psi are you guys running while off roading/ rock crawling? I'm running 35" yokohoma mts.
What is a good tire inflator/air pump I could buy for a reasonable price to re-fill the tires after leaving the trails? How big of a compressor is needed?
I can tell you that the model from Harbor Freight takes 2 HOURS to refill my tires from 15 PSI back up to 45.
It cuts out all the time and has to cool down before it starts again. And this is the model that attaches directly to the battery leads, not thru the cig. lighter plug.
You can definitely do better than that, but you'll have to spend some money. This is one of the many reasons I want to put an air compressor on my rig driven by the A/C belt. Or just mount a tank and fill it somewhere else before you go out and use that.
The correct pressure for you may be significantly different from the pressures used by others. It depends on the construction of the tire in question, the load of the vehicle, and the type of terrain. There is no one correct pressure for all variables.
You should experiment a bit with different pressures and see what works best for your setup. 1 or 2 PSI can make a huge difference in traction and comfort.
i usually will hit as low as 12 in the sand and stay at 15 most of the time on rocks. i prefer Co2. i have a powertank valve on a 20lb tank and it works great. i only use it a couple times per year. I dig the Viar ultra or heavy duty system. i may end up with that one of these days.
but MV50 or MV90 are great choices .. to be honest they will do great job up to 32 - 34 PSI ..beyond that barrier it will take a while ..
x2, I run soft ATs and do fine at 16-18. With a stiffer tire, you'll need to go lower.
