Just like you are doing it. Sockets without the wobbly joint seem to allow for more torque. You may want to go up a size in your ratchet (or add a piece of pipe) to get more torque. The steel bolts are in aluminum and should come out without a ton of force.any tips on taking the throttle body off? the one shop here in town didn't have any 1/8" coolant hose so i need to patch whatever is leaking. taking off the TB seems like the most direct route.
any tips? the lower right was tight so i'm soaking it with PB blaster tonight.
how do you guys get out the two bolts at the bottom? also how do you get them back in? they are quite a distance and the bolts are long - also my extensions seem to have come with wobble ends - so it seems like it would be a bit of a chore getting them out and in without dropping them?
maybe i can put a piece of baking tin/foil or part of a cardboard box in under it while pulling it so if it falls i can catch it or something.
anyway trying to take it slow here.
i'm guessing i will slice open some 3/4" hose or something or go looking - well could i use bicycle inner tube to patch over it with some hose clamps i guess?
THANKS
