The Mule / 73’ with a past? (2 Viewers)
I believe that was the reason for the diaphragm clutch with all the fingers, easier on your leg muscles. I don't know why those three fingers are adjusted different either. I don't remember seeing adjusters on them, been many moons ago.
Diaphragm verse three fingers provides smoother engagement and more even disc pressure
While I’m here! I’ll show another fun treasure a user here had in their possession stored away. It was the old adage…. If you ask, you shall receive!! Super clean hardly any wear and had some slight rust staining I used CLR and 0000 steel wool o.
floor mat porn!!
Not sure about any adjustment on the fingers themselves, but if there is, it’s probably to ride on the throwout bearing evenly. I guess it’s possible that they would be accessible through the cover plate on the bottom of the bellhousing.
Yeah, but shouldn't the throw out bearing be sitting square on the input shaft, etc. I would think all three fingers would have to be equal.
They should be equal. I’ve never heard of adjustments on the fingers, just to be clear. So FIIK. Let’s see what the manual says about it…
TC and Trans are installed and everything seems to be in it’s spot. I’ll be back at tomorrow when I don’t have 50 distractions all day…looks like what I thought, a fine adjustment of free play on the TO bearing. Thank you for posting the pics.
Time for a beerS
Before u get too far here ...........
you need :
Transfer-Case 4wd Shift Shaft Boot missing Part Call out # 36318 part # 36318-60010
CALL OUT # 31126 BOOT, CLUTCH RELEASE FORK part # 31126-60010
take the time say 30 minutes , pull parking brake drum .....
Install a NEW OEM Seal call out # 36132A part # 90311-45018
use TOYOTA FIPG
orange Transaxle and Gear Box HOUSING sealant
00295-01281
- Smear generously over both male splines use a cue tip smear same like in and on FEMALE parking brake drum inside splines
- Mate Together in SAME Exact order removed ,
- KEY point : NOTE staked NUT Manual STAKE punch detent , use
torque wrench , apply FSM required TOURQUE ONLT and NEVER past Original STAKE PUNCH
Detent Marks impressions
- if you have a COTTER KEY style rear park drum and cqastle nut detail parts note cotter pin locations with paint dots like a BB ball timing flywheel 7' marl for example same exact way
- used a ROUND or field made square 3/16 drift punch re-stake to original factory location ONLY , NEVER tighten beyond , u have a crush sleeve detail inside here ........fyi
- or replace cotter key same exact location removed from after pre load inital tourque step by steps in 3spd J-30 FSM chapters
- Test Pre-load per FSM best u can with a spring schale ideally , or the like
- if you don't replace seal leaks to come now or soon after easy to replace now ,
- KEY POINT NOT IN FSM : apply oem OARNGE FIPG ONLY NOT NAPA permatex EVER to be clear , if you skip this Updated asn widley accepted TECH upscale and modlern skool of thought step by FIPG step , Geat OIL WILL Seep and leak from between the male and femail p[arking brake drum splines from inside the t-case , i can say 110% it will sooner rather then later if not allready happening now ..........
You have a UNICORN TROPHY TRUCK in my opinion @Blastservices :popcorn:
a 1973 FJ55 Modle ID Code is simply
FJ55LG
PM me your full frame # i can try thru my complex hand recorded records during my Reproduction DATA ID plate maker days years ago it now seams
narrow down your production date pretty darn well if you have a NOn-USA Import or missing the drivers door usa Spec. Data Plate maybe ?
i am the life long Dedicated care taker of this for well over 15 years :
YES, i know wrong front fender combo lamps ... 🤔
1/79 FJ55LG-KA USA Spec.
I
don;t know the exact number imported in 79 but ain't all that many i can say for sure , maybe someone can chime in ?
ALL 1980 USA Spec. Imports FJ55LG-KA 's were Special ORDER Dealer type Build Sheets 100% Only
i can only imagine maybe around the same number 1983 FJ40 usa Spec. imports comparison here
i only ever Hand-Made 2 1980 FJ55 sets of Data ID plates , both were Verified USA Spec. via original Drivers Door Smaller Plates
FJ55 Drivers Side Door Plates are always mounted on the Drivers Door Itself , NOT the jamb like a FJ40 that i saw 1968 - 1980
YES , 1968 indeed too .......
there is a
RICH and KILLER KOOL FJ55 History if you Dig hard online and well here in MUD Advance Search Archives as well :)
Need some help!
I sourced a radiator from a post 74’ truck. The parts breakdown shows a pre 74’ and post. I assumed radiator core got an extra row or something with the production of the 2F. Anyways the one I sourced showed up and doesn’t flushly sit against the radiator support. Can any pre 74’ owners send a pic showing the same pic I have here? Maybe it will help decide if I go further with this radiator or keep looking.
I added a complete view also. It has the cutout on the driver side vertical support that would copy the cutout on the later shroud as well.
Need some help!
that's a SNAPPY Sweet looking OEM ORIGINAL NipponDenso Unit there .............
in the blurry back ground upper LH side of above image ?
care to share ............. :D
you need :
use TOYOTA FIPG
00295-01281
Both the shift boot and clutch fork on order… appreciate the keen eye Matt.
This truck has turned into a slight project / constant challenge to make it operate as it should. I purchased it because of a need to have a mode of transportation in NC. Figured I’d grab something I’ve wanted since my college years and this truck was sorta what fit the bill. I wanted a unrestored preserved truck as orignal paint does make me happy verse someone else’s short cuts and lack of proper steps. I sacrificed and got this one because it was basically completely taken apart and zinc plating done on every single item that they could think of. It just meant to me that it didn’t need to be fiddled with for the most part. Or so I thought.
I already introduced this to another thread but now I’m finding i need a place to land the documentation of all the work I’ve done and am doing. Get answers and advice here and there and maybe get some missing doodads.
That color looks great!
