Get some! sub'd
Amazing how simple the thing looks with the body off. Wish I could do that each time I needed to work on the truck!
A dream of mine for sure! This gives me more reason to try and make it out there next year.
I gotta do my phh and a couple oil leaks. Can I hire that body removal service?
Ford had that idea. Now everything on a Ford truck requires that the cab be removed.
If your interested in helping out let me know, I'm sure we will be able to use all the help we can get! It is something that I think everyone should experience at least once...
Nice progress! Those housings are a work of art! I thought you had to run the same suspension style that came from the factory, I didn't realize that coilovers were an option.
Are you fabbing new motor mounts to get the engine up an inch? Can the TC move up 1.75" without coming in contact with the body?
Damn those housings are beautiful! I can't wait to break my 8" R&P so I can put a Ruff Stuff 9.5 in the front![]()
I'm not sure if the 1.75' will clear the body, with the body on I measured about 1/2" clearance from the trans/t-case to the body, the rules allow for a 1" body lift, I may have to get the BFH out and do some "custom" work to the tunnel.![]()
That's a lot of custom work to be done with a BFH! I'll be watching
, I'd love to tuck mine up.Have you taken into account how the extra 1.75" will effect your front pinion angle?
can you run it without a hood? that thing needs one huge louver hole. sweet set up! Can I have your old doors and stuff? or is it all tossed?
Just remember that if you run heims they will need to be replaced often. When Ford developed the Raptor they tested heims on their suspension but found that they wear out too quickly. The nice thing about Johnny joints or poly bushings is they have more give which reduces impact loading on everything else and last longer so you don't have to change em after a few races. Im not saying heims are weak, but they wear out very quickly because they have no give, and their often not rebuildable. If you own a trophy tuck its no big deal because you have a race team that rebuilds the truck after every race. Also have you thought about port and polishing the head? You might gain 20 or so hp. Does anyone offer more aggressive cams for that motor? It stinks you can't use forced induction, those motors can handle a lot of forced induction. Ive heard of guys getting like 800hp or more.
http://extremelandcruiser.com/found...-1fzfe-is-through-a-brian-crower-stroker-kit/
later and I have everything off. I got all the knuckles and full float spindles turned down and ready to be installed. Got the rear lower links mounted and started working on the rear upper wishbone, I am defiantly going to have to put a slight bend in the upper links to clear the cross member, I don't think it will be too bad.
I'd argue that it's incredibly important for a wishbone setup because the loads under lateral stress are almost entirely axial. Rotating it vertically allows the lateral forces to load the rod end radially. Most manufacturers state that axial loads on a rod end are only in the neighborhood of 12-18% of the radial load, so bear in mind the joint is much weaker the way you have it. It might survive in the "wrong" orientation, but you wouldnt' want to prematurely wear it, either.Need some advice, the center rod end at the axle, I know it "should be mounted horizontal as opposed to vertical how I have it now. Does anyone know how critical this is? I could possibly mount it horizontal, but I would have to make a custom bracket.
This is at full stuff.
