Builds The honey badger build (1 Viewer)
I personally do not like the look of the Maxxis tire. Looks like it should be on a forklift or something 😃. The Mickey Thompson are much more aggressive.
Picked up this insanely expensive fire extinguisher 🤦🏻‍♂️ Think I will let my 40 burn before I use it 🤔. And the fancy quick release. Also got a new stand alone trans cooler. Funny they match haha. I didn’t plan that .
Also placed a 3000 dollar order at Spector 🤦🏻‍♂️ So I should get 2 new bolts and a gasket 🤮😃. 3.5 weeks it’s time to thrash 🏃🏻‍♂️
More 💵 💵 💵 💰 💰 💸 💸 💸
Id love to give a home to those Maxxis, but distance is a problem.
Did you drive all the way to Reno for that stuff??
yep ran down today.
Worked on getting the trans cooler installed and the trans tunnel back in last night :bang:. pulled the seats. and fuel tank , such fun I needed to check fitment because i went to a twin stick and did not want to weld the sticks in first . Like everything else this will take a bit longer than expected. I was supposed to have it in the Come Up winch booth this weekend but i pulled the plug on that last night . Its not done :(. 30 days and it will be on the Rubicon/ Fordyce Stay focused :steer:
2 down 2 to go. 🤦🏻‍♂️ Got my new trans cooler mounted. And powder coated some more stuff. This is the lid to the under seat tool box that I will never use 😃
Goal is to have all 4 tires mounted ,trans cooler hooked up. , new winch installed and trans tunnel and seat back in by Sunday nite 😳. Sat is dead since I am going to the PNW overland show
damn man, I just got caught up on the thread. what an epic build! can't wait to see this thing on the trail :beer:
4 tires on and 4 tires gone 😃. Also a few parts came in today 😞. Most will show up Tue . So I am running up to the PNW overland event tomorrow. Bummed I was supposed to bring the 40 to be in the Come Up winch booth. Next year 👍. New tail lights installed . Lots to do on Sunday.
What do you guys think I should get next 🤷‍♂️ Kinda sucks I have to pull the transfer case off before Sept to check the spline count 😞. I needed to figure that out because I have Rubithon in Sept 🤦🏻‍♂️ If I pull it I don’t want to put it back in .
To find that spline count, couldn’t you remove the rear propeller mount or T/C rear cover, then remove the nut and spacer. Look at the shaft and count the splines. No need to remove the T/C.
So i figured it was a 32 spline TH 400. but the guys at AA said that it could be a 27. :bang: I will try and figure out a better way
Oh those splines, I don’t know of a short cut.
Yep once again this flippin TH400 trans rears its head . The 1 piece i have not touched on this thing . This may be the straw that breaks the TH400 back :D
Id get rid of the SBC. Then id cut it in half at the b pillar and stretch it 10”. You got time. Maybe some 44” boggers, needs more aggressive tires for sure.
