Build The honey badger build
So i made a post in the 40 section here ;). Since this 40 had zero wiring :bang:. Making the engine run is easy with the SBC. but having no gas gauge has left me nervous since i have no clue how far i can go . So i pulled the gauge cluster and looked at what i had to work with :hmm:. Not much . but enough . i also found what was left of some wires in the frame. honestly i never paid much attention to them since they were just cut off . After looking closer i could see a yellow -red wire. and on the cluster there is a yellow -red to the fuel gauge :oops:. I also seen on the cluster that a sol.id yellow must be the feed to the gauge since in jumps to the temp and oil as well . So i put a hot wire to the yellow and wired the yellow -red to the yellow -red ( from the gas tank sending unit . And Boom no we didn’t blow up but the gauge did work . Score . Since i was in there i figured it would be nice to have tail lights :cool:. i found the brake light switch of coarse everything was cut off of it . hmm but it had 1 wire coming off ? this made no sense to me i looked up the switch and it shows 2 wires . OK So for fun i ran a hot wire to the 1 wire and put my test light to the other side and We have brake lights when i step on the brakes :steer:. I did print out the wiring diagram so now i am good i can wire everything like oe . Really it is very basic . When i got this 40 it came with a brand new painless wiring kit but it has way to many things so i didn’t want to use that . but i can use the wires to get the colors correct or at least close to oe and not just 500 red wires and some black wires .
What I had to work with 🤦🏻‍♂️
Not sure what they had that for but it’s gone . I do not have the amp meter wired. Since a run a single wire GM Alt . I don’t need that anyways I can see all the vitals on the sniper screen. Really I just wanted a Fuel gauge 😃. I think I will get a Dakota gauge cluster eventually. We will see
So things i dont like :cool:
I am not 100 percent sold on the front bumper :hmm:. I think the 40 looks really clean with a real stubby front end . I know this will protect it but still think it can look better . Will circle back this winter .
Tires. Not a fan of the look. but they work well :hmm:. I need to get the Baja pro x. on
The top . I like the look better with a top on . I am picking up another hard top so i might make 1 a summer hard top ( just leave the glass out ) and a winter :hmm:
Transmission While the TH400 may be strong. I HATE it. So its either going TH350 or back to a manual one way or another the motor is going back and at that point this motor /trans just may go somewhere else .
Steering it works fine. but i have everything to go full hydro and that is the plan At that point i will circle back to the front bumper since i can bring things in some then without the Saginaw box .
Once i get it out a few times i will learn what i need to work on
Are you feeling ok? I love my 80, but it'll never crawl like the 40 you had before or this one I'm betting
Actually i am depressed We should have been on the Rubicon Today . I went out today to actually load the 40 on the trailer for the first time and the trailer is 82 wide 40 is 86 then i noticed that 1 of the tires on the trailer was coming apart . I came in and listed everything for sale. Over it all
The worst part is i listed both very cheap and people still offer stupid numbers or do i want to trade for a ford galaxy and there kids atv Ugg So i am probably stuck with dang things for life :bang:
Curious, clarify HATE regarding the 400 ? what hate ? noise, heat, shift points, slam shifts, too soft, what stall is the conv ?
the length it pushes the engine to far forward
Well No one wanted it . had a few offers of 5000k and a Chrysler 300 . I had to sleep on that deal. but in the end i did not want to disappoint them with my piece of junk . So The Saga continues . I pulled the listings.
Figure since I am stuck with this thing I better make it so I can get it to the dump someday . So I started operation make it work . Fat body will have no excuses now 😁
