Builds The honey badger build (10 Viewers)
One of those kinda of days 😳😃
So the axle specs are Fj 80 width . Hi 9 diff 488 gears ARB locker. FJ 80 Knuckle balls and Knuckles with Hi steer arms RCV 300m axle shafts
That'll do! Look forward to seeing this thing come together. I'm still confused though as to which truck this is going under?!?
Boy that is the daily question in my head. hahaha. I have more money in Axles and parts laying on my floor than i care to think about . My house is starting to look like a Diamond Mine ugg. So the Blue 40. rt now has FJ 60 axles. It is getting Diamond housings with Tundra diffs with D 60 outers and going to 42s. The yellow 40 /green / black /art project. has 40 axles and is getting Diamond housings with FJ 80 outers and the Hi 9 diff . And the rear it has the Diamond 9.5 FF going to 39s . Then i have the diamond 9.5. Mini outer front and 9.5 FF rear for my FJcruiser .
Some serious 1st world problems you have on your hands :grinpimp::grinpimp::grinpimp:
Been chipping away at things. Dropped my diffs of to get powder coated and then can get those assembled . I did fire up the engine 😃. So at least I know it runs .! Now I can put it all together. And just keep sanding and painting parts .
I did fill the reflector holes in the aprons. I don’t like those . Working on the bib now
I think the PO sanding this 40 with a grinder. sheesh sand prime sand prime sand prime. uggg. o well its giving me a project i can do :)
I have a couple HVLP guns nothing special. The spraying is the easy part. its the. sand prime sand prime part that takes forever. but thats ok .
Here is one of the kick vents. This is the first time I have really painted a car . Well I did my Samurai but I used Raptor liner on it so that was different
So I got a piece bent to start on the front bumper. Started messing with it a little. Thinking about clipping the ends then boxing them in 🤷‍♂️. Also last week I was down at another shop and seen a really cool idea . I would have to get a 8274 🤔🤦🏻‍♂️ To do it.
Thinking 🤔
I think I will make a stinger the same angle as that on the winch Similar to the hood line also 🤔.
