The Car Care Nut talks UR V8 blown head gaskets (21 Viewers)
It's not nonsense or misinformation but I do think there is some missing information. It would be good to know the exact coolant change service history for the failed engines.
In the video we are told the failed 200 was taken care of by the owner and that it was his "baby". Does that mean it had the coolant changes done according to Toyota specs? (10yr/100k for the initial, every 5yr/50k after that)
TCCN's recommendation only differs from Toyota by cutting the initial coolant change in half. Implying the initial extended change interval is the problem? I wouldn't be surprised if many folks are (also) ignorant of the switch to 5yr/50k changes after the initial change and they are waiting another 100k to change it a 2nd time.
The service history would be interesting this is like the few 5.7's that have crazy oil consumption it effects a small handful of trucks, but was caused by beating on the motor before the pistons rings have time to seat if I remeber reading correctly. So the owner may do something to exacerbate the head gasket blowing.
I am 99% sure the UN uses land cruisers so does the red cross and other global organizations. If head gaskets where a major issue I am positive they would not be using them in lethal environments as war zones, remote areas of Africa etc.
Do these international variants use 3URs?
My truck is a 2018 w 62k. I was aware of the 100k coolant change interval (1st time). I was not aware of the 5 year part, guess "Life Long" was stuck in my head kind of like the ATF statements some dealers make.
I have some test strips arriving today.
I'll probably replace my coolant this weekend, cheap insurance if it anyway helps prevent a blown gasket. I've been very proactive with the other fluid changes so why stop here. It's a pretty easy job based on what I have read and the FSM is pretty clear on what to do.
Guess the coolant flush threads in the 200 section will start seeing more action.
Looks good. Not much towing but the truck is heavy, lots of upgrades and mods. Lots of trails and highway.
No worries.
My question, which I posted on his channel as well. How come there are million mile tundras and other which use the same engine if this sounded like a wide spread problem. I heard of desert cruisers which they use for tourist sight seeing which have 500k Kilometers on them.
Fully agree. My 3UR is in my Tundra. He mentioned in the video a GX460 is affected also, this implies all UR engines are affected by the issue. There are literally millions of UR V8s on the road in all the continents, dont know about Antarctica. UR is in high durability/abuse applications and high performance applications. All have a solid reputation of reliability in general. If this were a common issue, or even rare issue, I'd think someone else would have discovered it. I think its something to consider, but realistically, not lose sleep over. These engines came out in 2007. The oldest ones are closing in on 20 years old. No the UR is not perfect by any stretch, but for head gaskets to suddenly now pop up as a issue now seems off. The fact this is the first time majority of people are even hearing of this shows its very rare. Its been 20 years. Maybe not the UZ engine, but take whatever you think the most reliable engine in the past 20 years is and look hard enough and you will find a rare issue. I still personally would have 0 issues buying a maintained high mile UR.
Takes 20 years to put 200k miles on it. 10k miles a year being average, right.
Just as an example, Subaru had a bad rap with head gaskets blowing at 100k miles if you remember. They cured the problem with a multilayer head gasket design. Now they last 200k miles.
Something to think about.
The one benefit of being in Chicago... if I ever blow a head gasket, I'm going to have my truck towed to TCCN's shop in the southwest suburbs.
Here's to hoping that never happens though :-)
I'm at 8 years and 83K miles. Almost all towing something, often a 4K lb camper with a mix of forest roads and Interstate to campsites. Also fairly frequent short trips (3 miles) of deep sand in summer temps and 4Lo. Original coolant. Looks and tests like new for both pH and freeze protection.
so it would appear as though CCN is wrong in your case. Your coolant is as good as new.
So I’m the second owner of the 200 in the video. I sold it to the current (third) owner. It was originally a Georgia vehicle and I bought it here in Illinois in early 2020 because it was super clean and completely rust free.
I’m trying to remember the mileage when I bought it, but I think it was around 135-140k. At that time, it had an aftermarket radiator in it but I’m not sure when it was done, so coolant was changed at least once before I got it. I’ll look to see if I still have the carfax when I get home from enjoying Pure Michigan later this week.
I changed coolant and all fluids when I bought it around 140k miles.
I discovered the valley leak around 165k in late 2022 and at that point I had already bought a 23 GX460. I fixed the valley leak, and decided to sell it with about 170k miles on it to the current owner in early 2023. It’s currently got about 220k on it, not 200k as the video said. Current owner had car care nut replace the radiator with Toyota around 200k. I traded the GX460 in on a 2018 200 not long after.
So to recap:
Coolant was changed at least once in the first 140k miles (80k sticks in my head from the carfax for some reason).
I changed coolant at 140k miles.
I changed coolant at 165k when I did the valley plate.
Car car nut changed coolant around 200k.
So to recap:
Coolant was changed at least once in the first 140k miles.
Sounds to me like you changed the coolant at least to spec or close. And coolant degradation was not the issue, at least to the limits of your control.
So to recap:
It's nice to get the facts. Thanks for sharing.
In the video he states that the block is warped
2 thou. Toyota states if the warpage is more than the maximum, replace the block. The maximum warpage allowed is 0.00276 in. So the block is less than maximum, why would you recommend to replace the block. Unless you see some kind of a nick or imperfection. When you put everything back together the torsional effects will distort the deck anyways. If the engineers are happy less than maximum then it should be good to go. Also in the video he stated the heads needed to be machined that they were 2 thou of warpage.The standard warpage for the cylinder head is a little bit less than 2 thou, 0.00197. maximum warpage for the cylinder head is 0.00394 in. So according to Toyota, the block and the cylinder head are within specification. Unless there's some surface damage that we can't see in the video, I'll bet putting on a new head gasket and slapping it back together is going to work for a long time and the proper fix.
If it was my 200 in the video... it would be getting a new head gasket, and I'll bet that would take her for another 200 k miles (yeah, I know it's conjecture) :p
So to recap:
Sounds to me the first owner overheated the 3UR-FE as part of the radiator issue, then replaced it by an aftermarket one, potentially sold it soon thereafter. Most people do not watch their gauges frequently and will not immediately stop by the road. IMO that explains all there is to it.
Sounds to me the first owner overheated the 3UR-FE as part of the radiator issue, then replaced it by an aftermarket radiator. IMO that explains all there is to it.
I don’t know if that’s the case though. It’s had at least 80k miles put on since then - 30k by me and 50k by the current owner.
It’s my understanding from the CCN video that the block deck warp coupled with the thicker head gasket needed to compensate for the machined head would be enough to cause head gasket issue sooner rather than later. Running a new head with the in spec block warping may be fine but the cost of new head, possibly 2 because he had only town down one bank, along with the other costs associated with replacing heads and you’re getting to the cost debate of engine vs roll the dice on heads not being terribly far apart.
At least that’s my pea brained understanding of what he was getting at in the video.
This begs the question of how long after a bad overheat would it take the head gasket to fail. 80k does seem like a long time but it may not be. I have to think that modern head gaskets are damn tough.
Thanks for coming with the facts on this truck. It’s always good to know some history for issues like this.
