The Bicycle Thread
Thanks man. They all have their intended purpose. The Pistol is so great for riding around here but the BTR is possibly the most fun. In the winter I pretty much only ride the BTR -- definitely helps rebuild skills lost by riding a full suspension wonderbike. Plus it saves the pivots and suspension on the other bikes from all the mud/grit/water. I'll keep an eye out for your 80 at the trails. I'm at Cisco and Creedmore a lot.
I get turned around at Cisco and can never figure it out... I haven't ridden OC in awhile, love that place though. I ride 286 a lot and sneak in a few quick rides at Forest Ridge just because its so close. Will definitely keep an eye out for your 100, it is SWEET!
@suboptimusprime I'm a bit of a jerk, but this is in no way intended to come across that way. Serious question. I actually started this thread but have very little seat time over the last 15 years (just look at my Zaskar in the first post for proof!). I've noticed the trend of dropping the top tube lower on the seat tube over the last few years. Can you, or somebody, explain the significance of that, please? My mind always goes to something like this...
(***not ACTUALLY @stevezero 's bike, but only because Santa Claus didn't like him in 1975.)
EDIT: I DO have a bandana to match that seat, and I DO wear it on occasion. Well, it doesn't have the weird yellow discoloration in the middle, but it's similar.
Basically, as bikes have gotten taller (due to larger 27 and now 29 wheels which have taken over the market), there has been increasing need to lower the top tube so that it's not in the way when getting over the bike for cornering, jumping or getting way off the back of the bike in steep terrain. Secondarily, it looks bad ass (IMO). Imagine rolling down this with your seat way up your rear end and no way to get your butt over your back tire. It would be suboptimal to say the least.
@JohnVee the tube drop is for men as they age. Their fellas start to hang lower and lower, and it prevents unnecessary contact. Maybe puberty will finally arrive, and your fellas will start to decend a wee bit. :flipoff2:
@suboptimusprime .....Serious question..... I've noticed the trend of dropping the top tube lower on the seat tube over the last few years. Can you, or somebody, explain the significance of that, please?
Basically, as bikes have gotten taller (due to larger 27 and now 29 wheels which have taken over the market), there has been increasing need to lower the top tube so that it's not in the way when getting over the bike for cornering, jumping or getting way off the back of the bike in steep terrain....
Bikes have also gotten taller from longer travel forks raising the height of the head tube (the fork on the Zasker had 63mm/2.5" of travel, the updated 29er cross country bike would have 100-120mm travel), which makes the tops tube APPEAR to be dropped more than it is because you have to slope the top tube more. Full suspension bikes may drop more than hardtails, often to accommodate the suspension design. But yes, they are dropped more now than they were.
@suboptimusprime I'm a bit of a jerk, but this is in no way intended to come across that way. Serious question. I actually started this thread but have very little seat time over the last 15 years (just look at my Zaskar in the first post for proof!). I've noticed the trend of dropping the top tube lower on the seat tube over the last few years. Can you, or somebody, explain the significance of that, please? My mind always goes to something like this... View attachment 2014404
My experience (being a USA cycling coach since 1990, World Cup director sportif and worked closely with Kestrel, Ritchey, Specialized, Rock Shox and others) the frame design began changing with the advent of exotic metals, carbon fiber and engineering principles that required stiffer frames due to the materials and higher loads the materials were being put under. Please remember those traditional frames are made from butted steel tubing brazed together into lugged head tube/seat tube/bottom brackets, very thin steel tubing. Then came aluminum, titanium, carbon opening engineers minds to what a bicycle frame could look like.
Dropping the top tube to meet the down tube, making stronger “triangles”, particularly when the need to have a top tube meet the down tube at/near the seat where the top of the down tube, where the seat is mounted, takes very little lateral load.
Most significantly, this frame change also allowed manufacturers to accommodate a larger buyer population with fewer frame sizes. Back when I rode bikes, frames came in single centimeter sizes, such that frame manufacturers had to make many different sizes to accommodate the variety of human sizes. Additionally, the tooling costs for making so many varieties of frame sizes were additional costs, where now most manufactures make 3, maybe 5 sizes if they include women.
Next step came the advent of dual suspension, where the additional frame loads and stress points of frames brought the triangles tighter and many more to help with rigidity in the bottom bracket and rear suspension pivots.
Working with Kestrel and their monocoque carbon frames, where they eliminated the down tube on their road bike, allowed them to effectively design the carbon layers such that the top tube became a suspension beam where the down tube/chain rails became a rigid, unflexible platform where all the energy from the rider was applied to the pedals/cranks/chain/wheel. I was part of testing where lateral flexion was measured at the bottom bracket and the Kestrel, without a down tube, measure the least deflection.
Sorry to go on so long, really just an engineering/cost reduction over time. Thankfully, the industry didn’t get stuck and moved forward with the times...
From full suspension bikes to singlespeed rigid, the overall design of the bike still follows the same core geometry with a downtube, toptube, seattube, chainstays, and seatstays. The key here is tweaking each of those individual components to make the bike perform and feel that much better on the trails. Progressive frame geometry dictates an modified offset fork, a long top tube and downtube (reach), short chainstays, and a more vertical seat tube. We are finally getting to the point where mountain bike frame geometry finally drops the carryover geometry from road bikes.
2015052
I love the 11.6. You have some serious rides there.
Thanks man. It is for sure a bad ass shock and you know it's special when you're in Pisgah.
HIGHLY recommend watching "Klunkerz" if you haven't. Really good documentary about the advent of mountain bikes. I was totally expecting @Mtbcoach to show up somewhere in this Cali-based history of "Klunkerz".
Glad you saw that, more focused in Marin, I was in Santa Cruz Mtns closer to where Tom Ritchey settled. I worked for Ritchey and rode his “secret” trails near his home with the World Cup team. We used Schwinn Heavy Duty frames (my paper route bike) riding in the hills between Los Gatos and Santa Cruz.
Cool movie, can say I have a met all the players much later in their lives (mid 90’s) and appreciate what these innovators brought to cycling...🍻
I’ll close my sh!t talking of my insidious past, a life few ONSC friends know of...This article was published in Bicycling magazine, back when magazines were a real thing that one touched, felt and looked forward to arriving in your mailbox. Closely after this was published, I was offered to contribute to VeloNews under the “Single Track Mind” from ‘95-00, pontificating upon training methodology breaking tradition that included heart rate monitors, blood lactate testing under VO2 max protocols, watt meters and the worst...STRENGTH TRAINING, something few cyclists considered undertaking.
This image was a full page cover shot in a Euro mag as well as other US based mags, taking our team leader (Thomas Frischknecht) to the podium of the tour of Hawaii ‘96 being the overall winner that year. I rented a Harley that year, feeling large, hated having to drive the crappy rental vans to all the team meeting and press conferences, opted to be cool that year. Thomas went on to win a silver medal in the ‘96 Olympics and World Championships in Aus, later to gold after winner tested positive.
My young self in a photo shoot with Kestrel getting that butt behind the seat on a ‘94 Kestrel CSX, no mater the frame geometry, you don’t get your weight back, it’s not going to end well (sorry for the really crappy photo)...
Really cool stuff. We should hear more of these stories over beers and a campfire!
That is why I don't jump... that would be me as well. Bought a 160mm 27.5 to explore that space and just don't have the time or intestinal fortitude to send something like that. Hope all is well for Linden
My current montra for ramps: 'if it's over the knee, it's not for me'
Speaking of Windrock, I'm going to be in Knoxville next month... anything there a flatlander could ride? Most of the pics/vids I see are very STEEP
Tons of MTB'rs at Showshoe this weekend. We were there for the 4848 music festival. Shared the lift with some of the riders heard a LOT of good things about the trails.
