The 2H/12H-T/1HZ/1HD-T/1HD-FT Gturbo Alternative Tech Thread (1 Viewer)
Yep the boost is plugged. No exhaust leaks. One thing I could do is put some RTV on the intake manifold to make sure there's nothing leaking there.
410Nm / 129kw!!!
You can read and see my set up and results here:
410Nm / 129kw!!!
That's about 1999 stock 1HF-FTE power/torque but you're also smokey. Why are you running such low boost?
because the engine has 430thsd km on its clock!
why should I squeeze more out of it?
It runs good as it is and has decent torque and power.
No reason for me to get more as it is now
Here in South Africa the engines are rare and a complete rebuild is pretty expensive
bit more boost = less smoke + less egt
My EGT are fine, running low.
Boost maybe, the actuator I use is not acurate (Mamba rubbish!)
I pushed the car up on the local mountains here without getting worried about high egt´s
And I can easily overtake a slower car now.
As I said, its ok for now, much better what I had befor
You are smoking which fills your oil up with soot. A retune with more boost and less aggressive boost compensator will be much, much, kinder on your engine.
Where is your EGT probe and does it reach mid-stream?
Hi guys, I've installed an arashi td05-16 large on my 1HDT and it's seems awfully slow to spool, doesn't hit full boost of 19psi (I've installed a boost tee.) Till after about 2100rpm and even drops boost between 3rd and 4th which cause egts to spike up. Max egts under load on a hill are about 685 pre .
I've done injectors 3 inch exhaust and big end bearings recently. Any ideas please?
What exhaust housing and turbine wheel do you have?
