forum.ih8mud.com
410Nm / 129kw!!!
You can read and see my set up and results here:
1HD-FT after market Turbo set up
Good day, cause of this massive thread in this forum section I post separate my after market turbo set up which is working. I purchased following hardware: ( I do not promote or get any discount from this supplier!) My car has a front mount intercooler,3 inch exhaust, Snorkel and K&N filter...forum.ih8mud.com
My EGT are fine, running low.
Boost maybe, the actuator I use is not acurate (Mamba rubbish!)
I pushed the car up on the local mountains here without getting worried about high egt´s
And I can easily overtake a slower car now.
As I said, its ok for now, much better what I had befor
What exhaust housing and turbine wheel do you have?Hi guys, I've installed an arashi td05-16 large on my 1HDT and it's seems awfully slow to spool, doesn't hit full boost of 19psi (I've installed a boost tee.) Till after about 2100rpm and even drops boost between 3rd and 4th which cause egts to spike up. Max egts under load on a hill are about 685 pre .
I've done injectors 3 inch exhaust and big end bearings recently. Any ideas please?
