Tom I have a lead between the neg- terminal and the bottom of the bellhousing. It then also splits from the - terminal to the left fender but with my fender not in place at the moment I "earthed" that one to the radiator surround cum fan shroud. ?? Should I run some more straps ? When I tested for continuity on the block it seems to test fine ?..
...When switching the new multimeter onto Omega and without touching anything the default reading is 0.L. ...
..Connecting the two multimeter's terminals gives a reading of 0.3 ohms. ....
...Connecting the one to the neg- on the batt and taking a reading off the block, head and chassis(through the left fender mounting captive nuts) all gave a reading of 0.3 ohms. ..
...Armed with this I tried to take a reading of the FCM body- From the armiture housing(painted) I got no reading -just 0.L . From the gearhousing I got a reading but it was not stable and I really had to scratch around to get a stable reading of 0.5 ohms and higher. .....
...Then I went to the FCR body, initially it varied between no reading(ie 0.L) and jumping around. Some places would give 0.L and others would give 0.3 ohms. ...
...So I tried the preheat timer and starter relay bodies also and also got non-consistent readings. I then removed the FCR, preheat timer relay and starter relay. I sanded down all the mounting tabs and tapped all the captive nuts again to remove all traces of paint. This improved matters in the sense that on all the mounting bolts and the bodies of those 3 relays I got eventual readings of 0.3 - 0.6 ohms although it sometimes took a bit of time to settle. I then tried to start her again but still the Edic doesn't move. ..Any further Ideas ? Where/how/should I install additional earth straps ?![]()
Theo, unless you have a $400-$500 meter those low ohm readings will be meaningless. The resistance reading could be more than indicated or it could just be 0. Even with a good meter, you have to subtract the resistance of the probe leads from the total. If your meter has a "Relative" button then press the two probes together then press Relative. The meter will then be zeroed. But like I said, don't rely on the readings too much unless its something like a Fluke brand meter.
It was a ZAR R400.00 meter which equates to about $60
Will have a look tonight as there is a button but I am not sure if it is a "relative" button. .....
Best way of checking for suspected bad earths is to rig up some jumpers to earth. Meters are pretty useless for testing for that sort of thing even if you have a good one.
And mine says "1." (rather than "0.L." which must be the South African version of saying it) to show an opencircuit like that. But digital meters always have trouble with what to say for an open-circuit. They want to say "a very very very high ohms value" and if I was designing such a meter I'd get it to display "99999999999" right across the screen for this reading! (Perhaps Alex can tell us why they don't actually do this?)
Odd!
Australians would recognise how cheap my meter is because "Dick Smith Electronics" is an Australian company - yet my meter correctly reads "zero ohms" for a "dead short" like that:
Sounds like you have enough straps to me Theo ...![]()
.... Thinking(hoping) that possibly I have a broken wire(s) between FCR and FCM?? Anyway I could test this without damaging wires (eg by using scotch locks etc) ?
The solution has got to be simple. (The term - "Can't see the forest for the trees" - comes to mind. ..........Whatever this is will surely be staring you in the face! ..)
Well I'd hate to be responsible for you wasting your time and money Theo. So I'm not going to put my neck on the line and say I'm sure.
But, it looks to me that if you were to grab that image off Sandcruiser's site showing the muddy internals of his 28590-56090 FCR, rotate it 90 degrees and place it alongside the image you posted of the internals of your 28590-57010 FCR ( post #22) - they'd be identical!
..PS.And Theo - Why do you assume you can fit your FCM with its arm in any random position and that it will automatically put itself in the correct position (stop position) when you connect that connector? Perhaps it should do that ...... (I need help
You bet TOM !
This morning I fitted the 28590- 56090 to my 28590-57010 spec truck and it ran just fine - no difference at all![]()
Well I didn't forget and also tested this. Using a + feed to the M spade, I manipulated the edic arm to stop in the "run" position. I then left the ignition in the off position and reconnected the FCM connector. As soon as I did so, the Edic arm moved to the STOP position as it is supposed to do ..![]()
Argh, well after following this thread and read several others, I am still trying to work out what is wrong with mine.
I've carried out all the tests, and beside the FCM moving to OI position on turning the key to start, it remains there. It does work when I move by linking up to the M connection, but nothing else. The relay appears to be working as per the clicking tests detailed in here.
Any other ideas? I've just replaced some suspect battery connections as well, but nothing![]()
.... no movement at the FCM. I gently tapped the IG relay section, and click, the motor moved to the stop position. So off to the wreckers tomorrow to find a replacement, let's hope all goes well![]()
