Stock tire size w/ 17” rim (1 Viewer)
Minnesota
We have a ‘21 Luxury model w/ 19” wheels. I am not happy with the tire selection available and am considering replacing the wheels with a 17” to increase options. What is the equivalent tire size using a 17” wheel? The truck is stock, no spacers.
That would be tire size 265/65/17. You can fit a 265/70/17 without rubbing.
Most GX models come with 18' wheels, which use a tire size of 265/60/18. They a dimensionally (nearly) identical to the 265/65/17.
Another plus in going with 17" tires is they are far more readily available and cheaper than than 18" or 19" tires.
Also, you'll have a little softer/smoother ride quality with the taller side wall.
I'm sure you'll like it! ;)
Also if you check your current speed with the GPS on your phone, I think you'll find your speedometer is a little fast (e.g.: reading 63 mph on the dash vs. ~60 mph on your phones GPS). Going up one size should put your speedometer spot on. Generally auto manufacturers will have the speedometers run a little on the fast side from the factory, assuming customers will want to do a little over the posted speed limit, being on the fast side will keep them right on the posted speed.
Also if you check your current speed with the GPS on your phone, I think you'll find your speedometer is a little fast (e.g.: reading 60 mph on the dash vs. ~63 mph on your phones GPS). Going up one size should put your speedometer spot on. Generally auto manufacturers will have the speedometers run a little on the fast side from the factory, assuming customers will want to do a little over the posted speed limit, being on the fast side will keep them right on the posted speed.
That's exactly what happened with me. I went up one size to 265/65/18 and now my speedo is bang on.
Tires of the same nominal size differ actual size. There was a .4" diameter spread between the smallest and largest 265/70r17s I looked at. Tire Rack has actual sizes.
Wheel offset will make a difference for fender clearance. I went to a slightly more offset wheel when I went to Falken Rubitrek 265/70r17s and had to do some heat gun molding of the fender liner.
  • Like
Reactions: r2m
Don't forget that the bolts on the front of the running boards will also rub.
