The $561 deal is going on again, just grabbed one.
where? Do yo have a link? ThanksThe $561 deal is going on again, just grabbed one.
It’s just the wheel but the air bag is super easy to switch over. At least it was on my ‘21 MY. There are 3 spring retention bars that you need to push out of the way with a small punch or screw driver to remove it, 2 wires to unhook and it’s out. Installation is reinstall the wires and simply push back on.Does the new steering wheel come with the air bag cover? Does the airbag swap over easily?
What additional parts are needed for this?
Thanks
This includes the steering wheel only (with switches), and you'll need to transfer your existing airbag. From what I understand, only airbags from 2016 to 2021 are compatible. If you're installing it on an earlier 200 model, it (the switches) might still work, but you'll need to find a suitable airbag and make sure there are no programming issues.Does the new steering wheel come with the air bag cover? Does the airbag swap over easily?
Thanks
Sharing my experience in case it's helpful to someone.
Even though I don't have a Heritage, just a plain jane '17, I ordered the Heritage edition wheel that someone posted earlier in the thread because I thought the bronze stitching would look sharp with my Terra interior. And also, it was about $100 less than the OEM wheel during the most recent 20% off sale. It does look good, but the leather is more of a gray color than the black on my OEM wheel. Not really noticeable once installed, and the quality seems far superior, but worth mentioning as I traded one color match (leather) for another (stitching).
I used this video, which I found to be the best one out there:
Installation was reasonably straightforward and tracked the video except for one big obstacle. I could not -- really, could not -- get the two screws holding the wheel weight to budge with any normal effort. I ended up stripping both of them. Then tried to drill one out, unsuccessfully. Finally got them out using a needle nose vice grip but they were really stuck....not sure why. Also, when removing the control panels from each side of the wheel I snapped off two very, very tiny retaining clips. I'm actually not sure how I could have taken the panels off without snapping them and it doesn't seem to matter on reassembly; the clips wouldn't be visible, and the panels are held in with two screws on each side. But again, worth mentioning.
Setting aside the time I spent struggling with the wheel weight screws, it was probably a 45 minute effort.
There is definitely a correlation between lotions
What correlation, I don’t use lotions and mine is peelingThere is definitely a correlation between lotions (including hand sanitizers) and the peeling that happens with these 200 steering wheels. Interesting to see his wheel was not the one with the wood on top and bottom, which I initially thought were the only ones affected by the issue.
Good job on swapping them. I am not that mechanically inclined, so had my shop do it for me. The new HE wheel you bought is not really gray, it should be the same color as the one you had in your truck (except for the bronze stitching). The thing is, when new, they have a more matte gray look and with time a shiny patina forms and the gray turns more into a shiny black. It happens to all kinds of leather too. It was a good call using the HE wheel with the Terra interior. The stitching really match.
This is how I see. It is a hit and miss. Some won't peel and will only chip here and there (that was the case in my 2020HE). The chips still bothered me, so I replaced it. Some will peel regardless, but if you use lotion or hand sanitizer (here is the correlation) they will peel even more to a point it will look like you have a mouse as pet that loves to chew your steering wheel. Bottom line, the leather used by Toyota on the 2016+ (yes, even 2020s and 2021s) is junk, so plan accordingly to buy a replacement after owning the car for a couple years.What correlation, I don’t use lotions and mine is peeling
But the new OE replacement wheels won’t peel?This is how I see. It is a hit and miss. Some won't peel and will only chip here and there (that was the case in my 2020HE). The chips still bothered me, so I replaced it. Some will peel regardless, but if you use lotion or hand sanitizer (here is the correlation) they will peel even more to a point it will look like you have a mouse as pet that loves to chew your steering wheel. Bottom line, the leather used by Toyota on the 2016+ (yes, even 2020s and 2021s) is junk, so plan accordingly to buy a replacement after owning the car for a couple years.
Time will tell.But the new OE replacement wheels won’t peel?
Hit and miss again. We start all over....But the new OE replacement wheels won’t peel?
My 2020HE factory steering wheel looked near new when I changed it out. I only did that because I wanted a new sportier look with carbon fiber. I sourced a Japanaese manufactured steering wheel thru a Japanese aftermarket vendor. No heating element, but I very rarely used the feature on the factory wheel.But the new OE replacement wheels won’t peel?
