Malleus
Far west of Siegen
Not in North America...heh, heh
It means that I have to move the drag link to the direction of the red arrow correct? But if it throws the steering wheel off, I might just live with a quarter turn difference as the main concern is the the alignments marks align and steering box centered.
After I find the center and reposition the steering wheel as "straight". The steering turns are equal both sides. After dialing in the drag link to fix off center steering wheel when going straight, the turns are not equal again both sides of steering.The safest bet would be to jack up the front end, run the steering all the way one way, then count
the turns to lock the other way and come back half of that. Set the vehical back on its wheels; pull the steering wheel off its spline and replace it pointing "striaght".
Ensure the lock to lock is correct by visually varifying the physical stops on the knuckles are contacted.
Then test drive and dial-in the steering wheel position with the drag link.
Have you checked that your hitting the steering stops on both sides front and back ?After I find the center and reposition the steering wheel as "straight". The steering turns are equal both sides. After dialing in the drag link to fix off center steering wheel when going straight, the turns are not equal again both sides of steering.Thoughts?
When looking at the stops do they look to be the same or close to the same ?
My apologies gentleman, the stops are looking good and very similar on both sides. One thing I noted is that, when the vehicle is on the alignment rack I noticed when adjusting the drag link the toe will move as well.![]()
Steering wheel factory spline position
forum.ih8mud.com
The OP isn't really listening.
Either your measurement technique is not correct or the tie rod ends need replacement as toe only changes when tie rod length changes.But I have to adjust the steering wheel one spline over to correct off center as adjusting the drag link alters the toe alignment.
My guess is they do things differently in MalaysiaEither your measurement technique is not correct or the tie rod ends need replacement as toe only changes when tie rod length changes.
