Between ~42 & 50mph my steering wheel rotates about 1/2" left/right/left/right/left/right until I either speed up above 50 or slow down below 42. It's not the tires as I've rotated them every 5K miles (for 45K+ miles) & it always does it. It does it real fast, each direction probably 4 times per second. WTH could this be???
The tires have been re-balanced (@ Discount Tire) EVERY time they've been rotated, w/weights add/removed/relocated every time on each tire. In other words, tires have been rebalanced @ least 9 times & the vibration is the exact same @ the exact same speed. Thanks!
I've gone over all mounts & everything looks/feels good. Control arm bushings are a bit worn but I figured they wouldn't create this specific scenario.
Having the same issue, sans the 9 x rebalance. I don't drive mine much at all these days, trying to keep her under 150K miles. As dumb as I sound writing this, could the tires develop an irregular shape due to sitting so much?
I mark the tires next to the valve stem with a silver sharpie. If you have lockers the tire will rotate on the rim thus throughing the wheel out of balance. Mine walked about 3 inches after 2000 miles.
This could be your problem. Not to bag discount tire. But try taking them to another shop with a different balancer. Ask for road force balancing. I had the same experience with discount tire. Went to another shop after discount and they told me the tires were out of round and 9 years old. New tires solved it for me.
This means nothing to me. I had tires balanced over and over at 4 different shops trying to get rid of tire balance issues. I moved tires around to different corners 4 times. I went through EVERY SINGLE joint/bushing in damn truck to find nothing wrong and still couldn't prevent what I felt was tire imbalance or tires out of round. Always at the same speed with EXACTLY the same symptoms as you describe.
I pulled off all the wheel weights and went with internal balancing beads. That made things better, but still not right.
I finally gave up before I left for my 7600 mile road trip and purchased new tires. When the shop pulled the old tires off the rims, they found about a cup of water in 3 of the 5.
I now have ~45K on these tires and will be getting new ones w/in 15K more miles. I'll look then if there's water in them, unless I can get the tire shop to bust the bead and let me peak inside next rotation (which happens to be this week). I can see water getting in them if the air compressors used to inflate them aren't drained on a regular basis, which is probably the case with Discount Tire. Thanks!
