I believe stock caster is +1 degree isnt it? Those caster angles are way off my friend...someone correct me if I'm wrong please!
What is your caster angle?
A power steering conversion will not compensate for an incorrect caster angle.
Caster angle was -5.1 lft front and -4.7 rt front going in and coming out.
He's SOA, shouldn't he do a cut & turn?
I think we have discovered the issue. The SOA lift has the knuckles at a funky angle. The knuckles were never cut and turned. So, it is either spend $750 and get the knuckles cut and turned or change the lift to a 2.5 inch SUA lift with all new suspension and springs, etc.
I am leaning toward the lift and doing it myself. Also going to tackle front disc and fix the rear while I am at it. There will be a lot of questions to ask, but it looks like something I should be able to do.
I assume too much toe in now.
I couldn't agree more. I will be in Dallas this week, so I think it might be an expensive trip to CCOT. I am swinging by ACC in Atlanta tomorrow with the rig to get their opinion as well.Your front springs are a disaster waiting to happen. Get rid of them. When your suspension compresses, it is going to cause a buckle where the two long leafs are bent and nesting together. They must be able to slid back and forth as the curve of the springs makes them longer/shorter. That bend is also causing way too much castor problem for the small amount of shim that is installed now. John
