Builds starting my frame off (1 Viewer)
The frame off is coming along nicely. Keep up the good work, I can't wait to see the rest of it.
thank you! its an 87 sr5. I have the 4age from that mr2 sitting on the engine stand that might find a new home after the fj is on the road again.
my first try at making the replacement curved sheet on the back. had lots of fun today.
the cb antenna hole. decided to leave the dealer option antenna holes. I will probably buy a new antenna and use it there.
Ill try to finish the rest of the right side tonight.
got the sill cut out, gonna start making a replacement sill for it with some 2 inch square tubing, then continue the sheet metal work
Still havent gotten the square tubing for the sill so tonight i patched skme more rust.
these are some of the panels i made before installation.
tonights work. got em tacked up.
got the tubing for the sill on friday. im not going to re-use the old horns in the picture, those are going to be my templates. i will have to wait until i get some free time at work to cut those out with the plasma cutter. i took a picture of those old stickers i thought were cool. hopefully my next post will be of a finished rear sill and tub metal work.
made the sill corners tonight. not complete yet but almost.
first i traced one of the pieces i cut off 4 times onto some 3/16" plate, then i cut out the rough shape using the band saw. after that i clamped them together with the pliers and used a belt sander and angle grinder to make them all the same and smooth out the corners.
finished the rear sill and got the rest of the body panels i need done. now just need to install those panels and fix a few more spots. also need to finish up welding, i have just been tacking the pieces in since my argon/c02 is almost empty.
using the old body mounts to mock up the sill, still debating welding the sill closed
got another panel tacked in. was planning on getting the other side done too but my welder ran out of wire so i did some work on other projects. interesting development. found a 1uz locally that im thinking about picking up. ill know by saturday if im going to buy it
Awesome work!! I really like the job you are doing on this rig. It gives me hope on mine. I am keeping my fingers crossed that I can salvage my 1/4's like you did. More $$ to spend on the good stuff like lockers or a winch:hhmm:.
thank you for the compliments! i recomend doing it. its easier than i thought it would be before i started, and i actually enjoy doing it. it would probably be easier to buy the whole panel but i am on a pretty tight budget and so far i have spent less than $100 on material/welding wire.
that piece was my first attempt at making a replacement panel, it was thelast of the 16ga. sheet i bought and came up a little short so ill prob end up using that elsewhere. i would like to re create the factory lip out of some more sheet. still havent completely figured it out.
Looking very good! Great to watch it unfold.
Sent from my iPhone using IH8MUD Mate
didnt get any work on my 40 done this weekend. went out of town and helped my brother work on his project: 40 windshield on 55. also picked up some pick and pull seats for the fj, will have them.
ugly colored seats i got for 20 bucks a piece from a 1988 corolla gt-s. I had originally planned to put them in my corolla but they are too wide due to the drive shaft tunnel in my corolla so these will be put in the fj.
can figure out how to flip pictures on my phone.....sorry
finally got a chance to work on the fj a little bit. my "daily driver" has been keeping me very busy.
finishing up the right rear corner
cutting out more rust
i should have some more time to hammer out some of this metal work this weekend.
