I'm still banging my head against a wall with this no crank, no start issue. I thought I had ruled everything out except for the ignition switch but I installed a new ignition switch today and still no dice.
Here's the rundown of everything that has been done.
New Group31 AGM Battery.
New reman Starter. Have confirmed it functions properly on the bench off the truck.
New Fusible Link
New Ground wire from battery to block
New Ground wire from battery to starter
New OEM Ignition switch
Inspected the NSS. Pulled the plug apart, it was pretty nasty, and cleaned up the NSS side of the plug. Purchased new plug housing and repair wires from Toyota since some have found the plug wires corroded/damaged. I pulled each of the wires out and inspected them and they all looked to be in excellent condition with no corrosion, no broken wires etc. So I put the wires into the new plug housing and plugged it back into the NSS after cleaning it up.
I have bypassed the ignition by running a jumper wire directly from the battery to the starter as a way to check for a voltage drop somewhere between the ignition and the starter. When I do that the solenoid will click loudly and it sounds like the plunger is pushing the starter gear out but maybe not spinning the gear?
No difference trying to start in Park or Neutral.
Have tried jump starting, unsuccessful.
Have checked the ground wires. The one from the battery to the body is good. As mentioned the one from the battery to the block is new as is the one to the starter. The other ground that's near the back underside of the intake manifold is also good.
There are no blown fuses in the entire truck. I've heard some have had a blown taillight fuse or bad brakelight bulb that will cause a no crank condition. I'm not seeing any of that.
I guess I'm wondering now if it's a bad ECU. I supposed the NSS itself could be bad? I still have the repair wires for the NSS also but I really don't think they are the culprit. I'd love to hear any suggestions or other ideas.
This is the original NSS plug, pretty nasty.
Untitled by
Adam Tolman, on Flickr
These are the two wires/terminals that typically go bad on the NSS plug. These look perfectly fine to me.
Untitled by
The rest of the wires looked equally fine even though they aren't part of what would cause a no crank condition.
Untitled by
The NSS itself was pretty grimey and the inside of the plug didn't look good. A mixture of dirt and dielectric grease.
Untitled by
Untitled by
After cleaning up the NSS and plug
Untitled by
Untitled by
NSS wires in the new plug housing.
Untitled by
Untitled by
